Results 1 to 7 of 7
Thread: Remove parking brake handle
    Hello all,
    I am wondering if someone knows how to, properly, get the plastic handle off of the parking brake lever. I am thinking that it is just a press on and hammer off like a gear lever knob, but I want to make sure before I break things.
    Aug 2020
    SF Bay Area
    Mine was glued on and never,ever coming off without destroying it, which I did. New ones are easy to get at least, but I had to glue that on because the fit is also loose.
    - 1969 911T Ossi Blue #3981
    a block of wood and a hammer, just place the wood under the handle and hammer up. The bigger the hammer the better, as long as you have the wood under the handle
    That’s a bummer. Looks messy. Hopefully mine isn’t the same.
    Thanks for the reply.
    Quote Originally Posted by TheTorch View Post
    This is what I figured. I just wanted some confirmation.
    Thank you for the reply.
    Aug 2017
    el sobrante ca.
    use a heat gun to loosen the glue and it comes right off
    Jul 2006
    Corvallis, OR
    As Bob said heat gun is always your friend when glue involved.
    72S, 72 3.5L Signal Green, 914-6 GT Signal Green
