Thread: Electric window stuck down
    Oct 2004
    SW Suburbs of Chicago
    It's a 72, with the old style motor. It suddenly stopped working in the down position. I can hear the draw on power when I hit the switch, meaning (I think) either the motor has given up the ghost, or, possibly the window has gone too far down? It does have the rubber block at the bottom inside of the door. Before I inevitably open up the door for the umpteenth time, can a window be opened too far, and put the window regulator into such an angled position that the motor grunts, but can't raise the window?
    I've already replaced the driver's side with a later window regulator and motor. It may be time for the passenger side. Just looking for input before digging in. Thanks
    Mike O'Meara
    Reg #1043
    72 911T
    56,59 356s gone
    67,68 912s gone
    Mine has done that, I took off the door panel and loosened the motor mounting screws and tried again and it all started working. Maybe I relieved a little bind?
    Oct 2004
    Thanks, Ed. Pulling the door panel now.
    Mike O'Meara
    Reg #1043
    72 911T
    56,59 356s gone
    67,68 912s gone
    Oct 2004
    All I had to do is pull the door panel (and that D*** 10mm nut holding the forward pocket, with the window down!) and now it's working. Sigh. Much better than the alternative, but really? An electric gremlin is laughing at me. I guess it's an opportunity to clean the terminals on the bus bar, put it back together and wonder why. Thanks, Ed!
    Mike O'Meara
    Reg #1043
    72 911T
    56,59 356s gone
    67,68 912s gone
    Ed is da'man !!!!
    Aug 2017
    el sobrante ca.
    hey..... its just gremlins being gremlins.........
