Thread: Different tyre profiles
    mrimorton
    Guest
    On factory 73RS´s, why were the front tyres 70 series and the rear tyres were 60 series?
    Unlike on S models, the tyres were 70 series all round.
    Thanks in advance.
    p.s. Did Michelin ever make XWX´s in 60 series?
    pwd72s
    Guest
    Here's a place to play with tire sizes, and your answer may be here as well. But I think you'll find that the wider 60 series tires actually had a diameter close to the 70 series up front...
    www.miata.net/garage/tirecalc.html
    mrimorton
    Guest
    pwd, thanks for this. You are right, the 215/60 has the same diameter as the 185/70.
    If only I could find OEM's.........
  1. OEM tyre sizes
    By mrimorton in forum Technical Info
    Last Post: 02-18-2020, 07:46 AM
  2. Going from T cam profiles to E
    By Perry911 in forum Technical Info
    Last Post: 03-04-2013, 01:29 PM
  3. arch profiles
    By brembo in forum General Info
    Last Post: 01-21-2011, 04:23 AM
