Results 1 to 2 of 2
Thread: Faulty tail lights
    PNW 73S
    Guest
    Faulty tail lights
    'Evening fellow crazy people,
    I'm having a problem and could use some advice. While running my '73 at the track the other day, I was notified of a problem with my tail lights. Basically, they illuminate with the ignition and are not affected by the headlight switch position. Also, the brake pedal has no effect on the tail lights with the ignition in any position. I assume this indicates a faulty tail light switch...can anyone confirm?
    I don't know if it's related in any way, but earlier in the day I noticed my seat belt warning light illuminate for the first time since I owned the car. The driver's side seat belt was connected at the time.
    Many thanx,
    Tony
    PNW 73S
    Guest
    Nevermind, I found the problem.
    The flat washer located on the brake pedal push-rod was not making proper contact with the brake light switch "arm". After a few turns of the wrench on the adjacent nut, the washer was stabilized and the system works fine.
    Tony
  1. FS: SWB Tail Lights
    By juche_namja in forum For Sale: 911 Parts
    Last Post: 09-13-2013, 06:56 PM
  2. FS: SWB Tail Lights
    Last Post: 09-03-2013, 09:25 AM
  3. car pulling left, faulty lsd?
    By bosman in forum Technical Info
    Last Post: 03-12-2008, 11:19 PM
  4. SWB 911 Tail-lights FS
    Last Post: 06-27-2007, 02:38 PM
  5. 65-68 Tail Lights Set US $75 OBO
    Last Post: 07-24-2005, 01:32 PM
