Thread: Wheel Options
    SIIbEL
    Guest
    Wheel Options
    Does anyone have experience with using 16" x 6" Fuchs on an early S? The 15" tire selection is getting pretty thin.
    JuanLopez
    Guest
    FYI, The January 2002 Panorama has an article (page 74) on "Early 911 Wheel and Tire Upgrades". I have not read it through yet but it sounds like it will have the information you need. Juan
    SIIbEL
    Guest
    Is it true?
    None of you early s owners have ever tried 6x16" Fuchs?
    JuanLopez
    Guest
    Wheel Options
    I have not tried them but, I have a set of 6 & 7 by 16's with Dunlop SP8000 for sale!!!
    B rad racer2
    Guest
    Wheel Options
    I ran the 16's x 6 and 7's on my late 911S (77) narrow body. The fronts with 205/55/16 fit fine, but the 205's are a little wide for a 6" rim. It feels washy. In the rear I ran the same size, but these would rub a little.. The Fender lips were not rolled, and the camber was set at -1.4 degrees I believe. If you rolled the lip you would probably be OK.
    B_Rad
    CamB
    Guest
    It can be done...
    It can be done (I get to try it soon, but haven't yet). I am going for 205/50R16, as I have bought a speedo and transmission calibrated for that. To match stock size you need 205/55R16 I think.
    www.nosubstitute.org/911e.../side4.jpg
    www.starnes.com/images/tangle.jpg
    Cam
  1. What options on original 1973 steering wheel cover
    By Einar Irgens in forum General Info
    Last Post: 12-20-2013, 02:07 PM
  2. SWB ARB Options
    By Schläfer in forum Technical Info
    Last Post: 02-23-2009, 06:47 PM
  3. 67 options
    By ajwans in forum General Info
    Last Post: 06-18-2007, 05:15 PM
  4. Sport Wheel Options for a 67 911?
    By gruen911 in forum Technical Info
    Last Post: 12-13-2004, 09:40 AM
  5. 70 S Wheel Options
    By Atlanta-S in forum General Info
    Last Post: 06-05-2004, 08:57 PM
