Thread: Machining head in 2.0 to 2.2 conversion
    Baddger74
    Guest
    Bruce says the head needs to be machined to accept the different head gasket used on the 2.2. I am using the stock 2.0 S heads. Is that correct and what sort of machining is needed?? I now the combustion chamber needs to altered for the bigger pistons.
    911SRegistry
    Guest
    The '70 on engines use a different cylinder-to-cylinder head gasket and sealing surface. Your '69 heads must be flycut to match the 2.2 cylinders. Do you have a copy of B. Anderson's Performance Handbook?
    Sherwood Lee
    members.rennlist.org/911pcars
    Baddger74
    Guest
    Yes, that's where I read about the gasket change. I just wondered if the gasket machining was required or preferred.
  1. FS: Head Studs and head Nuts
    By cmcfaul in forum For Sale: 911 Parts
    Last Post: 04-26-2014, 07:48 PM
  2. Machining a '72 Filter housing for Therm
    By Kris Clewell in forum General Info
    Last Post: 03-06-2014, 11:06 AM
  3. 2.o to 2.3L Conversion
    By 50/50 in forum Technical Info
    Last Post: 01-18-2013, 10:43 PM
  4. Power brake conversion / de-conversion (1973 2.4E)
    By obrut in forum Technical Info
    Last Post: 12-13-2012, 03:18 AM
  5. Perplexing head - MFI in a 67 code head?
    By kenikh in forum Technical Info
    Last Post: 02-01-2006, 12:04 PM
