Thread: 67S Orange/Red koni struts
    Rick Cabell
    Guest
    I am in the suspension stage of restoration on my 67S project. I have the factory Orange/Red Koni front struts. My question is: Is the steering knuckel that bolts to the bottom of the strut painted orange or is it satin black like the rest of the car's front suspension? By steering knuckel I mean the arm that the tie rods ends attach to. Anyone with a original car could take a peak under their car and it would be much appreciated. That is if you are equipped with the factory Koni set up.
    pwd72s
    Guest
    Hi Rick, Keep in mind this is on my '72..not a '67. But the curved arm that comes out from the lower part of the strut assembly? On my car it's the same koni orange as the strut.
    Hope you didn't spend too many buks on Koni Orange paint..I sure can't distinguish between it and chevy engine block orange. But, for what it's worth, my front struts have never been repainted...they are "owiginal".
    Rick Cabell
    Guest
    orange konis
    Yes Paul you are right. The chevy engine block orange is the color as close a match as you will find.The LWB arm is orange because it's part of the strut.The knuckel on the swb cars is a bolt on item,thats why I have question. I have done these before but my memory has been damaged through the years and I am at a blank!
    ttweed
    Guest
    Re: orange konis
    Rick-
    On my original, (nearly) unmolested '67S the Koni strut orange stops at the joint with the steering knuckle. The knuckle and the arm going back to the tie rod are black, just like the rest of the A-arm.
    TT
    67eSse
    Guest
    Orange Konis
    can't post pic's to this but if you would like a jpeg of the correct colors for front and rears send me an email at fleming@bitstream.net and I'll send them to you.
    Bob
    Rick Cabell
    Guest
    konis/67S
    Thanks Guys!!
  1. Replies: 3
    Last Post: 03-26-2014, 03:41 AM
  2. Replies: 3
    Last Post: 09-15-2013, 11:13 AM
  3. FS: Koni Struts
    By drakon in forum For Sale: 911 Parts
    Last Post: 04-09-2013, 01:23 PM
