Thread: Steel Lug Torque Specs.
    BradAndersonPHOTOWERKS
    Guest
    Hi All,
    I'm replacing my alloy lugs with steel ones and was wondering if the torque spec remains the same or is higher since stripping/fusing is not such an issue. Wheels are 6x15 Fuchs on a '70 911E.
    Brad
    ttweed
    Guest
    Torque spec is the same regardless of material. I use 94 ft./lb. on both steel and alloy lugs, w/ spare application of thread lubricant/anti-seize.
    TT
    Guest
  1. Torque Specs
    By 356robo in forum Technical Info
    Last Post: 03-30-2007, 09:56 AM
  2. Throttle Body Torque Specs
    By jayzoll in forum Technical Info
    Last Post: 05-01-2005, 06:35 PM
  3. aluminum lug nut torque specs
    By NiceT in forum Technical Info
    Last Post: 04-27-2005, 02:54 AM
  4. Early 911S Rookie Needs Torque Specs
    By Bob Schaefer in forum Technical Info
    Last Post: 05-08-2004, 06:22 AM
