Results 1 to 2 of 2
Thread: SWB rear wheel bearing number
    herrongrey66
    Guest
    Is there anyone who has the SKF-number (I believe it is SKF-bearings) for the outer and inner rear wheel bearings at a pre'69 car?
    Thanks in advance.
    Roland Kunz
    Guest
    Hello
    6208 c2 ( Noz 100 % sure )
    Not sure if it is SKF or FAG but those numbers are descripimg the bearing.
    You need 4 bearings plus the o rings.
    Grüsse
  1. SWB rear wheel bearing help
    By ETW in forum Technical Info
    Last Post: 08-12-2013, 09:38 AM
  2. Rear Wheel Bearing How To
    By merbesfield in forum Technical Info
    Last Post: 10-29-2010, 07:00 AM
  3. FS: Rear wheel bearing removal puller
    By a911s in forum For Sale: 911 Parts
    Last Post: 01-03-2010, 07:41 PM
  4. Woo Woo Woo sound from rear end....maybe rear wheel bearing?
    By Chris Tallon in forum Technical Info
    Last Post: 06-27-2007, 07:59 AM
  5. rear wheel bearing
    By Paul Abbott in forum Technical Info
    Last Post: 01-21-2003, 10:32 AM
