Thread: Disconnecting Oil Cooler Lines
    JuanLopez
    Guest
    Any suggestions on removing the oil cooler lines?
    I'm replacing the fender mounted cooler with a much larger front valance mounted one but, the factory fittings are frozen. I have used AeroKroil and other penetrants but the fittings are still stuck.
    Anyone has words of wisdom?
    thback
    Guest
    oil cooler lines
    Hi,
    I did it by using the "flame thrower", a small gas-fed flame, heating up the connections. They will loosen quickly. I know it sound pretty rough, but it is not.
    Tom
    JuanLopez
    Guest
    Re: oil cooler lines
    Thanks Tom, Ill try that and get back here with the results.
    Thanks again for the help and quick response time.
    Juan
  1. 911 S without external oil cooler/lines ?????
    By J.Puppi in forum Technical Info
    Last Post: 05-14-2015, 10:12 AM
  2. PRE-74 Elephant Racing Oil Lines - Rocker Hard Lines to Cooler
    Last Post: 11-07-2012, 10:58 AM
  3. FS: 72 911 S Oil Lines and Serpentine Cooler
    By philvb in forum For Sale: 911 Parts
    Last Post: 05-01-2009, 12:53 PM
  4. FS: ROW 3.0;Oil Lines&Cooler;915 Trans;
    By 19-911-65 in forum For Sale: 911 Parts
    Last Post: 03-28-2007, 06:03 PM
