Thread: alternator light is on, ignition is off
    noradiator
    Guest
    I recently installed a rebuilt Marchal Alternator and a used voltage regulator. It replaced a Motorola.
    After doing the installation, and connecting the batteries, the alternator light went on. When I switched on the ignition, or started the car, the light goes off.
    The voltage reg. gets extremely hot after a few minutes.
    Where did I go wrong??
    By the way, which Alternator is better Motorola, Marchal, Bosch?
    Smadman
    Guest
    regulator is likely shot...
    The risk of used parts I'm afraid. If the light is on without the ignition turned a diode is quite likely punched through. As for the alternators I don't have the experience to know.
    Good luck.
    Roland Kunz
    Guest
    alternator
    Hello
    I remember that the SEV alternator should not run with the Bosch regulator and vice versa but but got supstitutet by the same aftermarked units.
    Not to forget there are different SEV regulators for different alternators ( 500, 900 and 770 Watt )
    Grüsse
    Quote Originally Posted by Smadman View Post
    Good luck.
    Hi I have the same problem, so I understand, do you mean a diode is shot on the alternator?
    Jan 2011
    DFW TX
    I would suspect the voltage regulator. Bad diodes in the alternator would result in a low/no charge situation. Light on with ignition off means the voltage regulator is routing battery voltage back thru the field coil circuit due to an internal short circuit.
    Let's review your symptoms to be clear:
    Ignition off, light glows
    Ignition on, light off?
    Engine running, light off?
    Voltage at battery with engine running above idle?
    Quote Originally Posted by the911Tprocess View Post
    Yes, if the battery light is on with the ignition off (with the key out, hanging on a peg on the wall) then one of the alternator diodes has failed. Only fix is to press in a new one: have the alternator rebuilt.
  1. Faint alternator light glow: don't get it
    By Greg D. in forum Technical Info
    Last Post: 05-21-2015, 12:05 AM
  2. Bosch CDI in '68 911- Alternator light problem?
    By 72tii in forum Technical Info
    Last Post: 06-19-2006, 06:42 AM
  3. Ignition Light / Dashboard Lights
    By Andy B in forum Technical Info
    Last Post: 02-06-2005, 02:42 AM
  4. alternator light doesn't come on ??
    By typ901 in forum Technical Info
    Last Post: 12-01-2004, 04:20 PM
  5. Alternator Light
    By philip guiral in forum Technical Info
    Last Post: 03-01-2004, 09:56 AM
