Results 1 to 2 of 2
Thread: tranny fluid
    jkolesa
    Guest
    tranny fluid
    i have a 1971 911S (5-speed). i'd like to change the tranny fluid to the redline synth stuff since i had such good luck with it in my old saab.
    just two problems: i'm not sure where the drain and filler are.
    my guess is they are the 2 hex bolts on the left side of the tranny. drain on the bottom & fill on top? if so do i have to pump it up into the top hole? how do i check the level?
    thanks.
    Roland Kunz
    Guest
    Tranyoil
  1. Which Brake Fluid to use ?
    By shipard in forum Technical Info
    Last Post: 01-17-2013, 11:40 AM
  2. FS: swf washer fluid reservoir
    By jim amato in forum For Sale: 911 Parts
    Last Post: 11-24-2012, 03:23 PM
  3. FS - 72 T Fluid Tank
    By Mudi in forum For Sale: 911 Parts
    Last Post: 11-03-2008, 06:30 PM
  4. Break Fluid
    By hdavis in forum Technical Info
    Last Post: 08-11-2007, 08:28 PM
  5. WTB: 65-67' Brake Fluid Reservoir
    By jhora in forum For Sale: 911 Parts
    Last Post: 10-20-2006, 01:13 PM
