Thread: battery modifications
    mwalker09
    Guest
    Is there a trick to converting from two batteries to one?
    mike 69s
    911SRegistry
    Guest
    Battery modifications
    No special tricks. Select which side you wish to mount your new battery, then connect the positive and negative cables to it. Insulate the cables on the side you're not using to prevent fireworks and welding FX.
    You may wish to find a battery with a higher CCA rating, but this might require a larger battery than stock and will require modified holddown hardware. Many folks use the Optima battery (800 CCA, doesn't spill and can be mounted in any position). Another option is to mount the battery in the smugglers box behind the gas tank.
    Hope this helps,
    Sherwood Lee
    Roland Kunz
    Guest
    modifications
    Hello
    Very simple. remove the cable to the other side.
    It is just a bolt off and remove it action.
    Grüsse
  1. Battery box
    By kissov356 in forum Technical Info
    Last Post: 04-12-2012, 06:31 PM
  2. Best battery?
    By johnchodgson in forum Technical Info
    Last Post: 01-14-2012, 12:24 PM
  3. Sealed Battery Recomendations for Battery Box
    Last Post: 11-13-2007, 06:31 PM
  4. Gel battery
    By RPMClassic in forum Technical Info
    Last Post: 10-04-2007, 10:36 AM
  5. Twin battery to single battery conversion
    By bulldog in forum Technical Info
    Last Post: 03-30-2002, 10:44 PM
