Results 1 to 8 of 8
Thread: Early Porsche hood crest
    Silver Surfer
    Guest
    Does anyone know a source for a correct early Porsche hood crest (orange and black)? Mine has the burgandy and black later crest.
    SS
    mwalker09
    Guest
    hood crest
    I just bought one, Stoddards has them. Ask for the early style..around 28.00 1-800-342-1414
    Dec 2009
    Copenhagen, Denmark
    Help! I can't get the early Crest to seat correctly. Does anyone know any tricks here? I heard you boil the rubber and use a tooth pick to get the rubber to seat to the crest. I guess the backs are self tapping and you use a 8MM socket on them? Also, the price has gone up to $65 from your $28 back in 2001.
    James Hurst #1638
    R Gruppe #514
    I have had several new orange bar crests and only on one of them did the rubber fit correctly. However, the pins broke off the back and dumped the badge out on the highway somehwere within the first month it was on the car.
    For the rest, I had to get creative. One trick I used was to install the badge with a piece of sandpaper behind it on all sides (gritty side up!!). I used the sandpaper to grip the rubber seal as I tightened the speed nut. So, As I tightened down the nuts, I gently pulled out the sandpaper and it pulled the seal out with it. It was slow, but it eventually worked. The key is to pull the seal out and tighten the nut down so that once tightetned, the seal stays in place.
    - Farrell
    p.s. I have a new unopened badge I will sell for $55 shipped, pm me if interested. It either came form Stoddard or Sierra madre (I cant recall which).
    An expert body shop guy showed me his trick, he cuts a slit almost to the edge of each of the points (three) in the gasket backing. That allows for a little more stretch to help the gasket stay on the emblem edge.
    Sep 2006
    La Quinta
    Great tip Ed...Thanks
    1965 911 #301111, Red Book Vol 1 "Cover Car," owned 53 years.
    1967 911 #307347, bare-bones, some road wear, a little surface rust, and a few dents..., owned 13 years.
    Registry #983
    R Gruppe #741
    Dec 2009
    Copenhagen, Denmark
    Goshdarn Ed! That's awesome, thanks for the tip.
    James Hurst #1638
    R Gruppe #514
    Senior Member platas's Avatar
    Jun 2005
    Spain/Houston
    Ed, what a trick, i will try it very soon.
    thanks
    San
    53 Pre A, 65 356
    70 914/6 GT
    65 912, 67 911
    71 911 Targa,72 E Tara, 73 911 Targa
    70 911 S,71 911 S,70 911 T,
    71 911 T, 72 911 E ,73 911 T
    74 911 Coupe
    74 911 Targa
    1972 RennSport Bus
    Early Reg # 771
  1. FS: Porsche Red Bar Hood Crest with gasket and fasteners - Early Style - Very Nice
    By m1franck in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 10-28-2013, 08:46 AM
  2. Replies: 0
  3. FS: Porsche Red Bar Hood Crest with gasket and fasteners - Early Style - Very Nice
    Last Post: 10-19-2013, 07:19 PM
  4. Replies: 0
  5. FS: Early Orange Porsche hood crest
    By surferjb in forum For Sale: 911 Parts
    Last Post: 05-11-2013, 05:21 PM
