Thread: Crane/Allison XR720 or Ignitor brand?
    Roland73S
    Guest
    Greetings. I scrolled through old postings but didn't find much on ignition upgrades, so here goes. Have any of you tried the Ignitor (R) brand points replacement part? Does it work as well as the 'highly recommended' Crane/Allison unit? The Ignitor looks to be a straight replacement for the points and a cleaner install. Just wondering if the smaller unit gives anything up to the larger Crane box. Any experience with this? Thanks in advance.
    Roland
    bhaubold
    Guest
    Pertronix Igniitor
    Roland,
    I have been using the Pertronix Ignitor in my 356 for about a year. As you said, it is a very clean installation. It has worked very well without any problems. I only wish they made a unit for my 67S.
    Bob
    Roland73S
    Guest
    Re: Pertronix Igniitor
    Thanks Bob... I looked around on Rennlist and it sounds like most guys concur. I'll give it a try.
    Cheers.
    Roland
    raspy22
    Guest
    Crane or Pertronix?
    After seeing a few break downs with other porsche drivers; I had put in the Pertronix Ignitor and had a good result. I like it because you don't have many wires and no external box to mount to the engine bay.
  1. Which Pertronix Ignitor
    By Irish911 in forum Technical Info
    Last Post: 12-09-2013, 06:13 PM
  2. pertronix ignitor
    By KarlHash in forum Technical Info
    Last Post: 08-07-2009, 05:05 AM
  3. Crane Hi-6 ign. box
    By 911pcars in forum For Sale: 911 Parts
    Last Post: 10-12-2005, 12:18 AM
  4. Crane ignition/MSD Box
    By amersbell in forum Technical Info
    Last Post: 12-13-2003, 06:43 PM
  5. MSD or Crane?
    By SprintStar in forum Technical Info
    Last Post: 10-20-2003, 09:48 PM
