Results 1 to 10 of 10
Thread: Oil line fittings
    GH68
    Guest
    Oil line fittings
    Last week after returning from Willow Springs, the normal 3-4 spot half dollar sized oil spots were accompanied by a large pool located just inside of the passenger rear tire. After inspection, it would appear to be coming from the fittings of the oil lines (currently all factory issue). All three that I could see plus the oil tank drain plug had oil drops.
    Is there anything I could do to better seal these lines? Silicon sealant? Better Earls type fittings? Just plain tighten them more? Does anyone sell steelbraided lines sized for the 911?
    Any help would be greatly appreciated.
    Gregg
    911SRegistry
    Guest
    You can try tightening them first (if they're loose). But old factory hoses leak through the material or at the hose/connector joint. Your options are to replace with factory or aftermarket "factory" hoses or try an industrial hose supplier who can replace the hose using your fittings.
    Guest
    Oil line fittings
    Orme Bros. Hoses in Northridge 818-881-7050
    They only did one of mine, but never leaked since.
    Chuck
    GH68
    Guest
    Thank you Chuck, I'll give them a call.
    Gregg
    Reviving old thread……So when assembling oil lines is a specific sealant recommended at connectors ?
    Or just tighten ?
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    I don't use any sealant. Rarely is the leak past the threads.
    Mar 2017
    Orange County, CA & Tucson, AZ
    Brad Davis also does great work rebuilding original oil lines. he is on the Registry and his website is http://www.911rennen.com/index.php
    Bill
    Early 911S Registry Member #4087
    Instagram: @myflat6
    '72T hotrod 210 0228
    '82SC Targa
    '97C4S (sold - and regretting it)
    May 2006
    CT
    +1 for Brad Davis. He did the oil lines on my 70E project. He used new period correct fittings supplied by Jimmy Tidwell. No leaks and look perfect
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Aug 2010
    Colorado
    I sent Brad some correct fittings and an extra piece of Elephant Racing's oil lines to match the others to the front cooler. It came back perfect.
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
    Hi Guys,
    Thank you for the kind words. Always appreciated!
    When crimping a line I always avoid a lubricant if possible. When assembling an ARGUS or TCH line I prefer to use Aeroquip assembly lube as well as anti seize on the the thread portion where the fitting mates with the aluminum collar.
    Your question may be asking about the nut to engine connection - I do not use any sealant, just a little anti seize on the threads, ball, and shoulders of the nut where is contacts the ball lip.
    Take care,
    Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
  1. WTB: oil line hose fittings
    By ret9191 in forum Wanted: 911 Parts
    Last Post: 03-25-2019, 06:41 AM
  2. FS: random oil line fittings
    By typ901 in forum For Sale: 911 Parts
    Last Post: 03-21-2014, 09:14 AM
  3. FS: Brake Line Fittings Renewed
    By 76911S in forum For Sale: 911 Parts
    Last Post: 06-04-2013, 02:53 PM
  4. WTB: oil line hose fittings
    Last Post: 12-26-2010, 12:58 PM
  5. Oil line metric to AN fittings source
    By bluefin9 in forum Technical Info
    Last Post: 12-21-2002, 04:27 PM
