Thread: Right Front Knocking Noise
    TripleR
    Guest
    Hi, I'm hoping for some help with a knocking noise that comes from the right front suspension of my modified 70 911under somewhat
    inconsistent circumstances. I bought the car as it sits fairly recently, it has gas charged Koni's and an aftermarket weltmeister torsion bar. When
    the knock occurs, it is as if someone struck the shock tower with a metal mallet, loud and painful. But, it does not always happen and it does not
    always
    happen when the corner is already under compression. It never felt like the strut to me because the damping performance always seemed fine, but
    looking at the car my mechanic could find no other explanation. After having taken the struts out he's found them to be in perfect working order.
    He then checked the bearings in the lower A arm and found nothing. He's stumped and I can't do any more than describe it. If anyone has had a
    similar experience with an illuminating ending, I'd love to hear it. Thanks very much, Eric Ryder
    pwd72s
    Guest
    Sound silly, but are the battery straps tight? everything else in the trunk thoroughly tightened down? Sometimes it could be the obvious and the simple...
    Guest
    Eric, I to had an aberrant noise coming from the right front recently and maybe you have the same deal....
    There's a lot of 'ifs' in this one, but here goes.
    If..you have a front oil cooler, and if it's the early
    radiator type, and if it has the louvered shield, and
    if that shield isn't tightly secure up against the inner fender. THEN, what happened to me was, only under
    the 'right' conditions (air coming up and around the
    shield from either the road or the tire itself) would
    make the damn thing oscillate against the inner/fender-
    inner/bumper area like an inconsistent machine gun.
    The fix was a strategically placed tech screw with rubber grommet to hold the shield tight against the inner fender .... Never so-much-as-a peep again.
    Eric, if none of this silliness applies then 'you got
    me!' .... and I'm sorry I couldn't help.
    TripleR
    Guest
    I want to thank you guys for you tips, I appreciate it - eric
    TripleR
    Guest
    I want to thank you guys for your tips, I appreciate it - eric
  1. Opportunity Knocking :)
    By Edwin Ek in forum Technical Info
    Last Post: 10-13-2013, 11:53 PM
  2. Knocking sound in steering (SWB)
    By Davz912/911 in forum Technical Info
    Last Post: 08-02-2011, 08:35 PM
  3. What is that noise?
    By raspy2point2 in forum Technical Info
    Last Post: 03-30-2010, 09:59 PM
  4. Grumbling Noise
    By boxster03 in forum General Info
    Last Post: 02-26-2008, 08:30 AM
  5. Replies: 2
    Last Post: 06-12-2005, 07:25 PM
