Thread: Corrosion Repair
    heirplane
    Guest
    Corrosion Repair
    My '73S coupe is showing surface corrosion on the right rear bumper where it meets the quarter panel to bumper seal. Any recommendations for surface preparation products? (Wurth, 3M, etc.) Are there any preferred primers or surface treatments?
    Steve Gackle
    ttweed
    Guest
    I have had good luck with POR-15. Go to www.por15.com and decide if it will meet your needs.
    TT
    heirplane
    Guest
    Corrosion repair
    Thanks for the advice, TT.
  1. corrosion
    By Cliff in forum Technical Info
    Last Post: 12-04-2010, 08:32 AM
  2. Front Hub Corrosion!
    By 304065 in forum Technical Info
    Last Post: 02-07-2010, 05:11 PM
  3. Weber white corrosion
    By 1QuickS in forum Technical Info
    Last Post: 09-15-2008, 07:02 PM
  4. Battery Corrosion - Replacement??
    By jcarpio in forum Technical Info
    Last Post: 02-13-2007, 01:43 PM
  5. corrosion protection
    By John Fusco in forum General Info
    Last Post: 11-25-2004, 04:35 PM
