Thread: VERY DODGY WIRING!
    elfenbein
    Guest
    VERY DODGY WIRING!
    I have a problem on my 69S whereby the engine will not switch off with the key unless I engage the parking brake!
    This is not as much of a problem as it may sound, but I wondered if anyone could point me in the right direction with the wiring as to where to start looking for the short. Other than this the cars electrics are fine( unless you count non-heated rear screen, clock runs fast and cigar lighter u/s!!)
    Any help much appreciated
    elf
    pwd72s
    Guest
    Man, I don't have a clue. But, as my dear departed friend, a 356 phreak and skilled mechanic once told me: "electrical problems are caused by either bad connections, or a short." Suggest first checking all connections, eliminate corrosion. Then...well, do you have a workshop manual with a wiring diagram? Gawd, how I HATE electrical problems! I know, not much help..just sympathy. Honestly tho, often just cleaning every connection I could find has often helped me. You see, I live in a moist climate, average annual rainfall about four feet a year.
    elfenbein
    Guest
    VERY DODGY WIRING!
    To pwd72s
    Thanks for the sympathy and advice.The car's coming apart soon for restoration, so I'll clean all the contacts when reassembling. I do have a wiring diagram so I'll study that too.
    The problem has been there for years. I have been lazy about fixing it!
    Elf
  1. Radio Wiring
    By turbochad in forum Technical Info
    Last Post: 12-31-2021, 08:52 PM
  2. Wiring up a Frankfurt
    By lexatola in forum Technical Info
    Last Post: 01-26-2011, 09:41 AM
  3. FS wiring harness '68 911 rhd
    By chasg in forum For Sale: 911 Parts
    Last Post: 12-26-2010, 07:53 PM
  4. Wiring diagram
    By Max (SD) in forum General Info
    Last Post: 07-26-2008, 09:16 AM
  5. WTB. H1 wiring connector
    By bobmagyar in forum For Sale: 911 Parts
    Last Post: 09-29-2006, 03:48 PM
