Thread: Weber question.......
    Is it possible for Weber carbs to be bench tested, sync'd and dialed in.
    And then put on the engine and have them working perfectly?
    Or is the only way to sync them, is on the engine?
    Thanks!!
    Regards,
    -Markus
    I'd say that you'd have to do it with them on the engine. I understand you can get them roughly right by doing a kind of pre-install routine . . . this would get it running.
    Perhaps someone more experience could tell you where to look for this pre-install routine, or contridict me completely.
    Phil
    Suffolk, VA
    Webers
    You should get them as close as possib;e on the bench. Final adjustment WILL require them to be on the running engine.
  1. Weber 40 IDS question
    By 68S_SK2 in forum Technical Info
    Last Post: 09-24-2017, 08:01 AM
  2. CIS to Weber conversion question...
    By joeblow in forum Technical Info
    Last Post: 08-04-2010, 02:42 PM
  3. Help! - Weber question
    By gilbert911 in forum General Info
    Last Post: 12-06-2006, 02:25 AM
  4. Weber Question 40 IDA v. 40 IDS
    By t6dpilot in forum Technical Info
    Last Post: 11-21-2006, 12:55 PM
