Results 1 to 2 of 2
Thread: Oil Level gauge jumps
    The oil level gauge is jumping from bottom to top today. Sometimes it stays at the top peg for a minute then bounces between top and bottom in quick bursts.
    Is this a short? loose connection? bad of failing sender?
    Anyone have a hint as to the cause.
    I'll be preping the car for storage this weekend and would like to put it away with everthing working. The plan is to start at the gauge and work back to the oil tank. Any advice would be great.
    Bob
    Minneapolis
    Bob,
    First, REALLY clean the two connectors and two contacts
    ...mine are spade connectors and spades, some are stud/washer/nuts and round lug. Also check the wires.
    Second, check the connections on the back of the gauge. Also check the wires there as well.
    Then, Check the sending unit inself.
    Ya never know, ya might get lucky with the first two options.
    Chuck
  1. matching of oil level gauge to sender?
    By lkadams in forum Technical Info
    Last Post: 10-29-2014, 10:44 AM
  2. Replies: 3
    Last Post: 04-09-2014, 02:23 AM
  3. Wiring question / oil level gauge
    By ze german in forum Technical Info
    Last Post: 01-12-2013, 12:56 AM
  4. WTB - '67 oil level/fuel level gauge and screw on shift knob
    Last Post: 03-31-2011, 11:29 AM
  5. Pegged Oil Level Gauge
    By FL-Frank in forum Technical Info
    Last Post: 03-09-2008, 11:46 AM
