Results 1 to 8 of 8
Thread: Camshaft sources?
    admin_old
    Guest
    Camshaft sources?
    Okay, I've seen reground cams advertised at MM for $300 and I've seen welded/ground cams advertised at WebCam for $1400. What other sources are there for cams that won't wear out after a few hundred miles or won't work because they're reground too much? I think $1400 is a bit much and was dreaming about Chevy and Ford camshaft prices.
    I ventured over to the EBS site for a look, but it's down for awhile. Btw, I'm thinking S type cams.
    Sherwood
    there have been some posts about vavle noise/alignment problems with regrinds with a smaller base circle. compare apples to apples. the $300 apples might be poisonus.
    72 911t * 74 914 2.0
    admin_old
    Guest
    Yes, I'm aware that some apples are not as equal as others. I've heard some regrinds go so far that the adjustment screw on the rocker isn't long enough to set the clearance. In lieu of good factory cams, the hard-welded and reground versions are a good option (as long as they're hard enough, ground accurately, have an effective lobe design and .......)
    Thanks for the reminder,
    Sherwood
    the only other people i could think of would be competion cams or crane. does jerry woods make or sell them? what about the 'g' grinds?
    my brother had a bad experience with an aftermarket cam from comp cams in a 454 donzi. they sent the wrong springs which ate the first cam. ate it the second time with the correct springs. the third rebuild was with the stock springs durring the break in then to the correct springs. ouch. three rebuilds and never hit the water.
    Junior Member
    Dec 2002
    Besides Webcam, They best sources for cams would be Elgin and Garretsen Enterprises
    cams
    UPS just delivered 2 sets of cams that I sent to Dema Elgin in Redwood city. phone# 650-364-2187
    He seems to be the man. Big experiance, small price!
    admin_old
    Guest
    Hi Bill,
    Welcome. Your insightful contributions will be an asset to the bulletin board.
    Regards,
    Sherwood
    Junior Member
    Dec 2002
    Thanks Sherwood!
  1. FS: 2.4T Camshaft and Camshaft Case
    By carlito in forum For Sale: 911 Parts
    Last Post: 02-18-2014, 01:54 AM
  2. Sources for trunk parts
    By mcaterino in forum Technical Info
    Last Post: 06-04-2010, 06:06 AM
  3. Windshield sources?
    By ulrichd in forum General Info
    Last Post: 08-06-2007, 01:31 PM
  4. Bosch cdi rebuild - sources?
    By racemor in forum Technical Info
    Last Post: 09-06-2005, 08:43 PM
  5. MFI tune/repair/rebuild sources?
    By admin_old in forum Technical Info
    Last Post: 01-05-2004, 12:06 PM
