Thread: Fan Shroud paint
    Fan Shroud paint
    Hi Guys,
    I have been reading for a while and am amazed at the knowledge transmitted on these pages. I am rebuilding my 73S motor and have a question about the fan shroud. I want to keep it original, but there are a lot of scratches that look to need painting. Has anyone had success painting this fiberglass piece so that it ends up looking acceptable?
    73 911S sunroof coupe
    No!
    I agree with schmidt Walter...
    The closest I've come is...
    Cleaning the hell out of it... then applying red leather dye with a daubber and alcohol let it soak in ... then put some pledge on it ... and in about 2 days of runnin the car the red calms down enough to live with.... kind-a
    As soon as you paint it it looks like it's been painted if-ya-know-what-I-mean
    i am way out of line here, but on the boats i have to repair and color match the gel coat. could be my only talent. ( looks to me that the shrouds have colors mixed in with the resin ie. no gel coat. )
    you could attempt to mix up some marine tex and add some pigment for deep scratches or gouges. ( available at skidim.com, westmarine, boatersworld ect ) your are supposed to be able to use this stuff on engine blocks, so it might be temperature stable. i don't know? might cost you 20 bucks or so if you can get it locally. worth a try.
    minicraft(.com) makes aresol (sp) spray gel coat in a bunch of different colors. you have to buy the hand pump to pump the catalyst in the can ( 50-60 bucks for the pump and a can of spray?)
    72 911t * 74 914 2.0
  1. Replies: 6
    Last Post: 07-04-2013, 11:53 AM
  2. Engine Fiberglass Cover-to paint or not to paint?
    By Varooom in forum Technical Info
    Last Post: 03-28-2010, 05:44 PM
  3. Red fan shroud refinishing - paint or dye?
    By james in forum Technical Info
    Last Post: 04-09-2007, 01:05 PM
  4. how do I remove paint from paint code plate?
    By 911scfanatic in forum Technical Info
    Last Post: 10-26-2005, 06:00 AM
