Results 1 to 2 of 2
Thread: Max Moritz Pistons/Pockets for S-Cams
    Senior Member Neunelfer's Avatar
    Dec 2002
    Sandy, Utah
    Has anyone ever cut deeper pockets in a set of Max Moritz pistons for use with S-Cams? I currently have three options for building my 3.0/3.2 MFI motor:
    1. JE's for 3.0 with 9.5:1. Haven't heard great things about JE's but it's still debatable. (noisey/expansion rate etc...) $1k
    2. Mahle Max Moritz 3.2's with 9.8:1. Just need to figure out if there's enough material there to cut deeper pockets for the S-Cams. Around $1k used?
    3. Mahle 3.2 RSR Pistons. Compression ratio would be reduced enough by using with the SC heads to allow for streetable CR (I'd like 9.8:1). Don't have actual CR figures though. Has anyone ever done this? Thoughts on what the CR might be? $3k plus! ouch (talk about deep pockets).
    Thanks for any input... the pistons are the great abyss I need to cross before moving forward on this engine. It seems as though everything is dependent on them.
    Eric
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    80 VW “Caddy” Pickup
    72 R75/5 Toaster Tank
    PMB Performance
    Love Us On Facebook
    Just perhaps, mind you Max Moritz has cut pistons for S cams....I know the second owner of RS lightweight #79 (final 2 of the VIN). It was an ex hillclimb car prepared by Max Moritz, if I recall what Roger (2nd owner) said. Since RS's ran "S" cams...???? but for a 3.2 bore? No idea...
  1. Value 2 liter syl, pistons and cams. 911 S
    By 911DP in forum General Info
    Last Post: 04-04-2011, 03:38 PM
  2. FS -77S 2.7 parts, E-cams,JE pistons
    By X-Faktory in forum For Sale: 911 Parts
    Last Post: 11-10-2008, 06:18 AM
  3. Replies: 2
    Last Post: 05-21-2008, 05:25 PM
  4. Max Moritz
    By BBausser in forum General Info
    Last Post: 09-25-2006, 06:42 PM
