Results 1 to 10 of 18
Thread: Batteries
    Batteries
    Am looking for some help in purchasing the two batteries for the older 911's (mine is a '72 E).
    Have checked out Interstate, Deka, Die Hard, and Exide. Sizes do not match up. Prefer to buy a battery with the side posts, rather than top.
    Any leads?
    Thanks...
    Vic
    Why do you prefer side posts to the top? To my mind, side posts are more likely to short out with anything metal sliding around in the trunk.
    hello fellow smter, i ordered some sonnenshein dry fits from lauderdale battery. top sae posts, but worked fine( i still have the rubber post caps). about 220 for both ups to the front door.
    see you at the next fun run, pending non stinky heat or some warmer weather.
    72 911t * 74 914 2.0
    Vic,
    I've run Interstates (two) in my 73' for years with no problems... that is when you check and maintain them.
    Here's something …
    I think it was one or our German contribuators who informed us that the small 12V VW 'under the rear seat' battery (67'-?) is idenical in spec and size to each of our early twin batteries and probably a lot cheeper….
    I havn't checked out the specs myself, however this guy is almost always right…
    ... maybe worth a look?
    Cheers,
    I got my Sonnenscheins at www.batteryweb.com. Talk to Dave or Randy. They were great to deal with.
    Jack
    1972 911S- viper green
    1970 914/6- tangerine
    1967 Ferrari 330GTC- oro chiaro
    Member, Human Race wit61's Avatar
    Jan 2003
    Pennsylvania, Northeast
    Bulldog and Tryan
    What model Sonnenschein did you end up ordering?
    http://www.classicvelocity.com
    70 911T Targa
    70 911E
    73 914
    If you go flying back through time and you see somebody else flying forward into the future, it's probably best to avoid eye contact....
    christie brinkley, but she was a no show.
    DF75 A212/36 sonnenschein 890640ppw.
    Now perhaps I see the price difference. I'm currently running the sonnenschein dry fits, a non liquid gel cell. The numbers on the box are a bit different. #A-200 then #081-90640. If I'm not wrong, bulldog is running the same as I. Tryan, are your batteries liquid lead/acid? Dry cell?
    I don't have the boxes handy, but mine were $198 each, ++. I think they're the Dry Fits. Car is in the shop, so can't check right now.
    Jack
    dry fits. i don't think they are gas mat or gels.
  1. Batteries
    By 71-911T in forum Technical Info
    Last Post: 02-12-2015, 12:57 PM
  2. Batteries
    By billm in forum Technical Info
    Last Post: 09-13-2011, 01:20 PM
  3. 70 911 batteries
    By kissov356 in forum Technical Info
    Last Post: 05-23-2011, 05:56 PM
  4. More than 2 batteries up front!!
    By mjk911 in forum Off Topic
    Last Post: 11-13-2008, 07:16 AM
  5. Batteries
    By lilacRS in forum Technical Info
    Last Post: 08-27-2001, 10:32 AM
