Thread: Wiring Diagram 1967S
    I have the factory workshop manual electical diagrams from page L 59 (911S, update Feb, 1967) but can not find the wire layout or components for the rear window wiper in it.
    This leads me to question what other components are missing. Does anyone have the next wiring update after this for the 911S model to verify what I'm missing. Is it in the Drivers Manual for 1967S or later?
    Items I'm looking for are:
    1) drivings lights (fog light are item 12, switch 36, fuse #5 - any difference for driving lights - or is it the same switch/fuse.) Are the horn grill driving light covered in any of the wiring diagrams if used in conjunction with the fogs?
    2) rear wiper, switch, and fuse
    The the wiring diagrams I have (911-1966, 911S-1967 and 911 Edition IV 1968) indicate a "unused" pin on the throught body/dash plug.... was this used for the rear wiper??
    Bob
    admin_old
    Guest
    Bob,
    You might want to look at some other early wiring diagrams here for the rear wiper circuit:
    http://members.rennlist.org/911pcars/WiringDiag.htm
    One of those is your "L59" diagram.
    Sherwood
    Early 911S Registry
    Thanks Sherwood.
    Found the section buried in the middle of the Webasto gas Heater instructions Section TRA 19 (Work Shop manual) Susequant installation of Rear Window Wiper, including wire descriptions and runs, Fuse 4.
    Bob
  1. Correct wiring diagram for 70 T
    By 356robo in forum Technical Info
    Last Post: 07-03-2018, 03:42 PM
  2. 68 Wiring Diagram
    By Norm01 in forum Technical Info
    Last Post: 05-19-2013, 04:23 PM
  3. Need a 1967 wiring diagram
    Last Post: 05-14-2013, 09:32 PM
  4. Wiring diagram
    By Max (SD) in forum General Info
    Last Post: 07-26-2008, 09:16 AM
  5. wiring diagram
    By targa911s in forum Technical Info
    Last Post: 12-19-2002, 07:09 PM
