Results 1 to 10 of 10
Thread: Rear parcel tray sheetmetal
    I posted this over on the Pelican board, not sure how many of you guys crossover...
    anyway, I'm looking for the rear parcel tray sheetmetal...Does anyone stock this? anyone have a clippable pre-73 car that could donate some more?
    thanks
    Per
    http://www.classicautosport.net
    Man,
    I think the factory used a 'fiberboard'... like the door panels
    I think I made my own out of 3/16" masonite
    Thanks, but this is under the fiberboard, the top of the engine box/parcel tray/rear window surround area.
    Per
    Chuck, you mean it's not metal? The piece you see when looking straight down through the back window? Over 35 years with these cars, and I learn something new every day...
    Sorry Per, now I got-cha
    No, I've only see it as part of the unibody... might be a Porsche dismantlers deal... maybe EASY or PARTS HEAVEN
    And... ya Paul, you old fart .. I think the ulpolstered tray up there is fiberboard underneith... hope to see you in May buddy...
    Cheers,
    Parts Heaven
    Easy didn't have any, Parts Heaven is checking.....kind of a PITA to drill out TWO sets of spot welds for all of the parts in question...but hey, better than fiberglass.
    Per
    I had a great doner car that had no rust.
    Replaced the whole one piece panel right down to the rear floor board. (to include the rear jump seat area) Between the two cars, I drilled about 300 spot welds out. I suggest using real body shop spot weld drilling bit. Have a few sharp ones for back up. If I could shrink some photos I have I would post them. It took about 25 hours to complete the job. There is no sign it was ever done after the seam sealer was applied in the factory manner.
    I've got the piece from Parts Heaven, a bit expensive, but restoration-design.com didn't have it....I also drilled out all of the spot welds and removed the original piece, cleaned up the area and am waiting for the clip to arrive from PH.
    While I was in there, I removed all of the horsehair/factory sound deadening sheets. Pans are really solid and will onl require a nice coat of POR15 before the car goes back together.
    I'll be documenting it for Classic Autosport...I've got some pics that I'll upload to http://www.classicautosport.net on monday.
    Per
    Per,
    Try Byron at 904-278-8574. I picked up a partial 1/4 panal from him today off a 76 911.{ I'm also finally doing rust repair.}
    He's got tons of 911/914 parts. Also try Stratton Auto in Orlando. Good Luck!
    Kevin
    72 911T
    I posted some more pics of what I'm doing at http://www.classicautosport.net, click on project car updates (left side of screen)
    Per
  1. Reproduction R / ST / RSR Rear parcel tray harness mounts
    By advtracing in forum For Sale: 911 Parts
    Last Post: 08-10-2012, 10:48 AM
  2. WTB 72-73 coupe rear deck / parcel tray
    By VintageExcellen in forum For Sale: 911 Parts
    Last Post: 05-16-2012, 02:54 PM
  3. Question about the rear parcel tray
    By classic in forum Technical Info
    Last Post: 03-11-2012, 02:06 PM
  4. Wtb parcel tray harness mounts
    Last Post: 09-01-2009, 10:55 PM
  5. Parcel tray-package tray, what do you call it?
    By Zeke in forum General Info
    Last Post: 01-30-2004, 05:33 PM
