Thread: 2.7 RS hp on a Dyno????
    I recently had my motor and MFI rebuilt to 2.7 RS Spec. I know from the books it is supposed to be a 210 hp motor.
    I am considering taking the car to Dyno Technology. They put your car up on the rack, give you print outs of your actual hp and ft-lbs of torque. The PCA/OC Region had an open house there recently.
    What hp and torque should my motor be putting out "at the wheels?"
    Thanks, Ray
    Dyno numbers
    Ray,
    Mine was 196hp @ 6300 rpm in 3rd gear to the rear wheels on the chassis dyno we had at Fletcher Jones Mercedes when I worked there.
    All the best!
    Roger
    Mine was 187HP at 6300 to the rear wheels in 4th gear on a Dynojet. With 15% drivetrain loss that's about 220 HP.
  1. Who do you guys use for dyno in so cal?
    By porschegal in forum General Info
    Last Post: 07-31-2012, 05:15 PM
  2. 901 on the Dyno at the stable
    By preS in forum Technical Info
    Last Post: 04-24-2010, 07:28 AM
  3. New Porsche dyno....
    By Chuck Miller in forum Off Topic
    Last Post: 07-22-2008, 10:28 AM
  4. Dyno in L.A.?
    By admin_old in forum Technical Info
    Last Post: 05-21-2003, 02:54 PM
  5. Dyno readings
    By A67911S in forum Technical Info
    Last Post: 11-11-2002, 01:09 PM
