Thread: weber IDS carbs - jetting
    Question weber IDS carbs - jetting
    Who out there has info concerning IDS 40 jetting ---> 68 engine.
    What has worked for you as a street/autocross set-up?
    Also, feedback on ignition set-ups for the above system... what have you guys learned?
    Hope to have some answers so that project remains on schedule.
    Thanks, JON 67 911s with 68 engine.
    ORE67S
    67 911S-SILVER
    65 356SC COUPE -SOLD
    73 914 2.0 YELLOW [74K]
    74 914 1.8 WHITE
    Goldmember ttweed's Avatar
    La Jolla, CA
    I can't remember my jetting on the '67S at the moment, I'd have to go out and tear in to them to check, it's been too long. I'm sure there are others on the board who can give you a good starting setup. I have wanted to change to bigger venturis and try the tall booster venturis from the 906, but so far have left the carbs stock.
    I do remember going to an electronic ignition setup, using an MSD 6AL with a custom Crane trigger (my mechanic fabricated an adapter and used a bigger distributor cap to fit the unit, as I remember). Much improved spark over the stock ignition, no more plug fouling.
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
    La Jolla, CA
    Jon-
    Check this thread on the PP board for jetting info. Look at the chart posted there for the "happy 2.0S" engines. That will give you some setup ideas.
    TT
    Tom Tweed
    R Gruppe #232
    Read my surf novel!
    CARBS
    TT THANKS,
    THE THREAD WAS MOST HELPFUL, IN BOTH JETTING AND OPTIONS FOR IGNITION ---> IT SEEMS THAT THE WEBER BOOK IS CORRECT FOR 2.0 ENGINES............. LATER JON
    ORE67S
    67 911S-SILVER
    74 914 1.8 WHITE
  1. Correct Weber jetting for a 2.9?
    By s2guy in forum Technical Info
    Last Post: 01-21-2010, 08:48 AM
  2. Nedd Help With Weber Jetting
    By gruen911 in forum Technical Info
    Last Post: 09-23-2009, 04:59 AM
  3. Weber Jetting
    By pacarguy in forum Technical Info
    Last Post: 06-28-2008, 10:27 AM
  4. Weber jetting on a 2.2 E
    By RPMClassic in forum Technical Info
    Last Post: 05-06-2008, 11:44 AM
  5. Weber 40 IDA jetting
    By zaza in forum Technical Info
    Last Post: 03-08-2005, 09:51 AM
