Thread: S-Caliper Sping Plates, Same as A-Calipers?
    Senior Member Neunelfer's Avatar
    Dec 2002
    Sandy, Utah
    Hi Gang,
    I have a couple sets of S-Caipers that are need of the spring plates that mount between the pins above the pads.
    Question: Are the spring plates from the A-Calipers the same? I was under the impression the A-Calipers were of the same design only steel...
    I believe I can order the plates for A-Calipers but the S-Caliper part lists as NLA.
    If you have any spares laying aroung you're more than welcome to send them my way!
    Thanks in advance for the advice.
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    80 VW “Caddy” Pickup
    72 R75/5 Toaster Tank
    PMB Performance
    Love Us On Facebook
    admin_old
    Guest
    Can't say for sure, but they look identical in the printed parts book and the PET CD. Parts numbers are of little help as Porsche lists the parts kits that include the pin/spring hardware kit with pads (pads are identical in shape but are different in thickness of the friction material). There is an S spring only number, but nothing to compare it with an A caliper spring.
    Someone probably has the simple yes or no answer.
    Early 911S Registry web
    admin_old
    Guest
    Just saw these on Ebay. Thought you might be interested.
    Dec 2002
    Sandy, Utah
    Thanks!
    I needed the pins anyway... I was going to pick them up from Stomski so... for $20 bucks, I'll try them and post the answer.
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    PMB Performance
    Love Us On Facebook
    Dec 2002
    Sandy, Utah
    And the answer is...
    Yes!
    Thanks for the link. Now I simply need one more pair of springs of the GT project. Any extras floating around out there?? If not I'm sure they're fairly cost effective from Mr. Dealer. Roger?? ;-)
    Thanks again!
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    PMB Performance
    Love Us On Facebook
  1. Replies: 2
    Last Post: 08-07-2013, 07:21 PM
  2. Replies: 2
    Last Post: 02-19-2013, 11:13 AM
  3. FS: 911 Scuff Plates Sill Plates / Carpet Hold Downs
    By 76911S in forum For Sale: 911 Parts
    Last Post: 11-05-2012, 09:34 AM
  4. SWB big caliper adapters - put S calipers or A calipers on your early car
    By VintageExcellen in forum For Sale: 911 Parts
    Last Post: 11-08-2010, 09:23 PM
  5. Upgrade "M" calipers with BMW 320i calipers?
    By jameshtaylor in forum Technical Info
    Last Post: 08-01-2008, 06:21 PM
