Results 1 to 10 of 17
Thread: Ignition Systems for Twin Plugged 2.4LS
    Once again I throw myself at the foot of the knowledgeable people on this bboard.
    I've got my 2.4LS ready to go back together. I decided to port the heads for twin plugs (already done). Now, the question about 12 plug distributor or a more modern ignition system comes up.
    I have three criteria to trade off each other (in order of importance to me):
    1: Long term reliabillity, maintenance, longevity
    2: Period correctness (my bias is toward the 12Plug Dist)
    3: Cost (initial, as long term cost is sort of wrapped up in #1)
    I read in Wayne's new book on 911 Engine mods that the RSR repro distributor from Andial is like $2K! The other recommended more modern solution is the ElectroMotive unit?
    Can anyone shed opinions (or better, experiences) with going either the 12 Plug Dist route (Kurt's is a 935 dist, can I use that on my engine?), or the ElectroMotive one? Anyone? Bueller (god that GTO was awesome)?
    Chris Purpura @civilizedmisfit
    ___________
    Member #479
    Current Cars:
    1972 911T aka The "Civilized Misfit" Build
    See: https://www.excellence-mag.com/issue...vilized-misfit
    Miss February - EarlySRegistry 2023 Calendar
    1968 911S Ossi Blau/Beige Corduroy
    Past Cars:
    2019 911 Carrera GTS (sold, no regrets)
    73S - #1100 (restored and now somewhere in Europe)
    1997 993 Carrera 4S Black on Black (sold)
    Wayne's book recommend twin plugging if your compression ratio is higher than 10:1, plus your piston size is 98mm or more. Piston diameter of 2.4 is only 84mm...
    I can understand your enthusiasm as twin plugging is a great subject.
    Jan 2003
    UK
    The only comments that I can offer are that all original parts for any of the Factory-installed twin-plug systems used in the 911R/RSR/935 etc - both Marelli & Bosch- are hard to come by & very expensive.
    There have been numerous discussions in the past about having a batch of new Bosch twin-plug caps made but the cost of tooling for the limited demand would mean that cost would still remain prohibitive.
    Andy
    '69 911E----------->R
    Would the 964 twin distributor setup be suitable for an earier motor?
    Jan 2003
    UK
    Nick, the main problem is that in the earlier engines the distributor rotates clockwise whereas the 964 version rotates anticlockwise. You would need to transfer the 'guts' of an early donor Bosch (169 or 184 series) distributor into the 964 body (involving a certain amount of machining to attach/anchor the points plate) including the drive gear.
    Yopurp - contact Steve Weiner at Rennsport Systems:
    http://www.rennsportsystems.com/2f.html
    or Peter Sanchez at Andial:
    http://www.andial.com/content/911/twinplugdist.htm
    Andy
    '69 911E---------->R
    One of the Pelican guys, RACER911RS, put twin plugs in his motor, it may be worth dropping him a line
    PP BBS thread here
    Dec 2002
    71236 Brush Rd. Niles, Mi. 49120
    Question distributor
    If I were you I would look into Electromtive system (crank fire). It is the way to go! No points, I have it on my 67s, I don't have to use a timing light any more. "http://www.electromotive-inc.com"
    All the Big Boy Racers in my area use it. My earlyS is a track 1st street 2nd type of car with a plate for a drive on the street now and then. Works fine for me. It is what allmost all new cars use today. It was on the MODEL T Ford
    Grover #53
    1967,911-S
    Grover,
    Thanks, checked out the electromotive web site. Informative, but don't see the model for a 911 engine (all honda's, chevy's, etc..).
    Andy, Thanks for the links to Andial and Rennsport. I'll give em a call.
    God that guys engine on PPBBS is incredible (ly scary). I figure he and Kurt must be from the same gene pool.
    ___________
    Member #479
    Current Cars:
    Past Cars:
    Goldmember ttweed's Avatar
    La Jolla, CA
    yopurp- try the Clewett Eng. site instead. More Porsche oriented.
    What compression ratio are you running in your 2.4 motor? I have to agree w/ beginner on the benefit of twin-plugging a stock motor. It's very minimal, except for the cool factor (which cannot be ignored).
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
    Tom,
    Thanks for the link. Geez, maybe that RSR dist isn't looking so expensive, and definitely is cooler. I'm running stock compression, but advanced cam timings from Elgin. My understanding from some books is that I can advance the timing w/twins for more torque.
    ___________
    Member #479
    Current Cars:
    Past Cars:
  1. FS: electromotive twin plug ignition set up
    By pu911rsr in forum For Sale: 911 Parts
    Last Post: 04-09-2013, 05:34 PM
  2. FS: @BaT - 1971 E Twin-Plugged
    By richemj in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 01-30-2013, 07:48 AM
  3. WTB: Twin plug ignition set up
    By swade in forum For Sale: 911 Parts
    Last Post: 09-05-2011, 02:29 AM
  4. Switches for Twin Plug Ignition
    By PeterM1965 in forum Technical Info
    Last Post: 11-17-2010, 02:36 PM
  5. Fs! 911 Bosch Twin Ignition
    By 914-6gt in forum For Sale: 911 Parts
    Last Post: 08-13-2005, 10:42 PM
