Thread: HELP!!!!!!!! NEWCOMER with Porsche! OIL
    Hi , I recently bought a 911 S 1973, and I have some questions related with oil,.......!!!
    1) Which the working temperature, let's say at 60-70 mph
    2) which is considered like normal oil comsuption by 600 miles (in liters please!!!....I am sorry I am european!!)
    3) And last, mineral or Synthetic??
    Thanks all, I wait for your answer cause I am a bit worried
    Goldmember ttweed's Avatar
    La Jolla, CA
    Re: HELP!!!!!!!! NEWCOMER with Porsche! OIL
    Depends on outside air temperature, but 190-230F is a safe operating range.
    1 liter in 600 miles is not too much, but it is on the high side if you aren't leaking any.
    Are you trying to start a religious war? There are those that prefer both. I prefer synthetic, others will tell you it causes leaks and you should stick with a good dino oil like Kendall. YMMV.
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
    That's funny...Tom, we're pretty much in agreement. I answered the post on the general topics page. Juan? I'll bet your car is a sensation in Barcelona! Welcome aboard.
    Nov 2002
    Worshington State
    I ran Mobil 1 in my 65,000 mile Audi Ur Coupe Quattro and after 1500 miles it started developing leaks. I read this was due to longer molecular chains. I persisted with M1 for another 3000 miles and it kept leaking. Switched back to Kendal and the leaks disappeared.
    The 911 only gets Kendal dino-juice, not synthetic since it has 85,000 miles and already has a couple of miner leaks. From experience, if I switched to M1 I would have leaks like the Exxon Valdez.
    What about the temperature??? and oil consumption??
    I thought all the 73 S came with oil cooler but I noticed that my hasn't , can this be a problem??
    I do not know if I can get Kendal in Barcelona, which kind of kendall do you recomend?
    Thanks!!
    Juan (Barcelona)
    Thanks!!
    Juan (Barcelona)
    Not all '73 911-S's came with oil coolers. It was optional. Kendall, Valvoline are good choices and temperatures mentioned are fine but cooler is better. Push past 230 and then you need to pay attention.
    Early S Registry #235
    rgruppe #111
