Thread: Strut Upgrade for SWB (1968)
    Question Strut Upgrade for SWB (1968)
    I want to upgrade my struts to the 3.5" type spacing. Anybody have any ideas for a this upgrade path? Any info would be a plus, thanks in advance.
    Goldmember ttweed's Avatar
    La Jolla, CA
    Might as well buy a whole front end out of a wrecked Carrera and swap it all out. You'll end up with better brakes, better ball joints, a lighter crossmember, etc., for little more than the cost of new struts and shocks. I've seen them go for $800 or so...
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
    Carrera front-end question...
    Thanks for the reply:
    Does a Carrera front-end require any body modifications, welding, etc.? Will it bolt right in?
    Thanks in advance.
    La Jolla, CA
    It's a bolt on. The only welding that might be required is to put a U-tab on the A-arms for the droplinks from your front sway bar if you have one.
    TT
    Tom Tweed
    R Gruppe #232
    Read my surf novel!
  1. Replies: 2
    Last Post: 08-11-2013, 12:43 PM
  2. Got the upgrade bug
    By EA911 in forum General Info
    Last Post: 09-28-2010, 10:29 PM
  3. FS; Koni strut inserts, pn 86-1647 for Boge strut housings
    By m1franck in forum For Sale: 911 Parts
    Last Post: 03-08-2010, 10:19 AM
  4. 2.0 to 2.2 upgrade
    By red67 in forum Technical Info
    Last Post: 03-06-2010, 08:25 PM
  5. Weltmeister Strut Bar upgrade project
    By 911pcars in forum Technical Info
    Last Post: 05-01-2007, 03:12 AM
