Results 1 to 2 of 2
Thread: Oil Capacity for 911S?
    I am a little confused about the oil capacity for my newly acquired 67 911S. I read in some of the technical manuals that the tank and engine hold 9 Litres. Yet in an upfixing article on oil levels, it says no more than 7 quarts. I just changed my oil, and put in 9 litres. Did I over do it, and could this cause damage? My dip stick shows the level just below the high mark.
    Peter Aziz in Toronto
    Goldmember ttweed's Avatar
    La Jolla, CA
    Peter-
    Believe the manual. I have put 10 qts. in mine when changing the oil and filter. That's close to 9 liters, actually a bit more, I believe. As long as you are reading the dipstick correctly (with engine warmed up, thermostat open, idling on level ground), you are fine.
    Even when overfilled, damage is unlikely, as the excess oil blows out of the tank thru the vent tube and into your intake, causing billowing smoke clouds out the exhaust and possibly fouled plugs, but usually nothing more.
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
  1. FS - R style 72 oil tank - large capacity
    By advtracing in forum For Sale: 911 Parts
    Last Post: 08-09-2012, 07:03 PM
  2. Carrera RS tire capacity decal
    Last Post: 08-22-2010, 05:23 PM
  3. Gas Tank capacity
    By joetiii in forum Technical Info
    Last Post: 09-13-2008, 09:58 AM
  4. What is the capacity of the plastic RS tank?
    By EARLY911ZOO in forum General Info
    Last Post: 06-03-2007, 05:17 AM
  5. '72 Oil Capacity - Who's right?
    By jcarpio in forum Technical Info
    Last Post: 01-22-2007, 04:21 AM
