Results 1 to 7 of 7
Thread: picture of 73 horn installation?
    Aug 2003
    Van Nuys, Ca
    anyone have pix of the horns install on the 73? much appreciated!
    db
    Senior Member WHCJr72S's Avatar
    Bay Area
    horns
    db:
    here is a picture of the horns on my 72s. It was taken from near the floor. I hope that it helps
    Bill
    Aug 2003
    Van Nuys, Ca
    Perfect ! exactly the picture i was looking for
    thank you
    db
    Nov 2002
    Worshington State
    Most interesting. When I purchased my '73 a couple of years ago, it only had one horn and set of wires in the left wheel well. The other set of wires was found in the passenger wheel well. Not much room for the install with all the plumbing, but managed to squeeze one in.
    Aug 2003
    Van Nuys, Ca
    I've seen them two on one side , one on each side, snail small versions. But mostly the banjo style like the picture. The horn wiring on our particular car was all to the left side. there is a cooler on the right side, so maybe that dictates the install?
    I don't use a horn. I just put in the clutch and rev the engine.
    Charlie
    '66 912
    '50 VW Bug
    '89 VW syncro Tristar Doka
    '83 VW Westfalia
    Aug 2003
    Van Nuys, Ca
    that only works when you have a sport muffler here in l.a.. Even then those 2000 watt sub-woofer wielding Escalades with deep tint windows ignore you!
  1. SWB Horn Relay Picture
    By Brad Davis in forum Technical Info
    Last Post: 07-22-2014, 05:47 AM
  2. H1 installation
    By frankmar in forum Technical Info
    Last Post: 11-24-2013, 07:00 AM
  3. Antenna installation
    By cmcfaul in forum Technical Info
    Last Post: 12-15-2008, 01:12 PM
  4. Turbo Tie Rod Installation
    By George Klouda in forum Technical Info
    Last Post: 03-20-2004, 06:42 PM
  5. new antenna installation
    By 70flatsix in forum Technical Info
    Last Post: 12-15-2001, 04:27 AM
