Instead of posting all the same info twice, I started a thread over at the pelican on how I do the restoration process of the 911 body.
http://forums.pelicanparts.com/showt...hreadid=131251
comments? enjoy , Damon @ SERIES 900
Excellent work Damon. Great attention to detail.
Bobby
71' Olive 2.2E Targa / Early S #491
I've always considered the glass to be half full...that is until I reached middle age and realized that it is actually half empty.
Nice work Damon. I have a 67S that will be going through the same process in a few months. Mine, although, has had considerable cancer in the rocker and longitudinal areas. The floors seem fine, but will probably replace anyway. Any info you have that I may want to ask or check with on my frame guy would be appreciative. Also, notice you use restoration designs sheetmetal. WHat do you think (quality and fit)? Just talked with Bill last week. Sounds like they make a nice product.
Michael
72 911S Coupe, Sepia Brown
mjmoran writes:
the best you can do is look for someone with the Celette Jigs, it maintains the proper location of all suspension points for reassembly, if not, it is a roll of the dice. Meaning one has to continully check all openings for proper fit; doors,suspension etc. The critical measuremant from the outside front A arm to the forward crossmember is 19.56" . I have found pans that fit the jigs, however they did not fit the gastank opening, nor the front bulkhead correctly. there is fudge factor in the front a arm mounting, however, good enough is not always for the purist. Factory parts fit, aftermarket parts always need a bit of this and that. Restoration Design seem to be the best in aftermarket.
Damon @ SERIES 900
Sunapee NH
