Results 1 to 2 of 2
Thread: 911s front brake rebuilt
    I have a 1970 911s with aluminium front brake calipers.
    I recently had the right front caliper rebuilt since it was "hanging up" causing the car to pull to the right when braking. The brakes now work but have a soft spongy feel to the brake pedal. The shop which did the work said that this is normal and should correct itself in about 500 miles.
    I am puzzled by this since about 5years ago I had the left front caliper rebuilt and didnt have this issue. That work was done by another shop which sadly
    closed/retired.
    Does anyone on the forum have any ideas/thoughts about this?
    Am I being fed a load of nonsense and if so what is the solution?
    I would be very greatful for any ideas.
    Dallas, TX
    My brakes were a little spongy after I rebuilt my brakes. It took about 100 miles for them to firm up. Supposedly the new dust seals on the caliper pull the piston back further than broken-in ones, thus it takes a little more pedal travel to get the same feel.
    If it doesn't improve, bleed the brakes again, that should do the trick.
    Neil
    '73 911S targa
  1. Replies: 5
    Last Post: 02-11-2013, 02:17 PM
  2. Replies: 2
    Last Post: 10-12-2012, 01:02 PM
  3. 70 911S front Brake Calipers
    By Rennman in forum For Sale: 911 Parts
    Last Post: 01-25-2011, 07:57 PM
  4. 1970 911S Front Brake Calipers
    Last Post: 11-13-2010, 06:17 PM
  5. FS - 911s front aluminum brake calipers
    By jj83001 in forum For Sale: 911 Parts
    Last Post: 07-22-2008, 02:52 PM
