Thread: aftermarket steering wheels
    joelrkaplan
    Guest
    great info on Fuchs wheelds......thnx to all; well i picked up an orig owner 70 T overweekend and drove it 6 hrs. home......great ride;Re: steering wheels.... what is the difficulty of taking off and installing aft.mrkt st. wheels?...thnx again to all
    I've only removed & replaced my original wheel a few times, a pretty simple job. I would think that replacing it with an aftermarket wheel would be pretty easy. To remove:
    1. Unhook batteries
    2. Push down & turn horn button to the left
    3. See the big nut? Take it off.
    4. Pull up on the wheel...
    Dec 2002
    Birmingham, MI
    Not difficult, but a few things to know:
    -Twist OEM wheel horn pad counter clockwise to remove.
    - Get a deep socket and a long bar or broomstick to hold the wheel when you loosen nut. DO NOT loosen against the steering lock mechanism.
    -You'll most likely need a steering wheel puller to remove from spline - available at Sears cheap.
    - Aftermarket wheels require an adapter.
    I believe the process is well outlined in 101 Projects for Your 911 by Wayne Dempsey.
    Jared
    '73 911S #0793
    '69 912_ #0602
    Early S #0454
    RGruppe #0391
    joelrkaplan
    Guest
    JC when you say adaptor I guess you mean a momo hub or the like?..thnx again
    Jan 2003
    UK
    Check out this recent thread in the General Info section :
    http://d240157.u39.zeonhost.com/foru...&threadid=2148
    Andy
    Early 911S Reg #753
    R Gruppe #105
    joelrkaplan
    Guest
    great..noticed it after my posting...thnx
  1. Catalog of factory and aftermarket steering wheels
    By Original Poster in forum General Info
    Last Post: 11-24-2022, 12:02 PM
  2. Catalogue of period factory and aftermarket wheels
    Last Post: 11-24-2018, 12:01 PM
  3. Hooking up an aftermarket horn and steering wheel
    By luke-44 in forum Technical Info
    Last Post: 01-06-2014, 11:05 PM
  4. School me on aftermarket steering wheels
    By DJ911 in forum Technical Info
    Last Post: 12-18-2011, 11:07 PM
  5. Aftermarket wheels
    By rapido in forum For Sale: 911 Parts
    Last Post: 06-23-2010, 01:48 AM
