Results 1 to 10 of 14
Thread: oil question re 70 T
    joelrkaplan
    Guest
    Question oil question re 70 T
    I am learning about my new 70 T...upon visual inspection I noticed creamy looking film inside my oil filler neck..my first thought was uh oh but now I ask the board...is this normal condensation gunk?......oil on dip looks cool tho...
    Yep, normal condensation gunk...you may want to check the breather hoses leading to the air cleaner housing, make sure they are clear & clean. Also, try to drive in a manner to get oil temp above 180, to evaporate the moisture.
    Apr 2003
    Portland, OR
    I had that on my filler when my valve guides were shot. Now that they have been replaced, the gunk is gone.
    Harry
    Member #789
    2009 MB C300
    joelrkaplan
    Guest
    oil continued
    thanx for response...Harry D.(or any1else) a question for ya..when I run the car hard in say second up to 6k then decelerate and then get back on it I have smoke from exhaust...on a 114k car is this valve guides or rings or.....?only if car decelerates from hi rpm and then you get back on it does the smoke appear......nothing appears in ez driving...thnx again.
    Joel,
    Smoke after deceleration is classic valve guides... (or lack of)
    Smoke on hard acceleration is rings... (or lack of)
    Change the oil frequently... (if your not going to do the valves soon) ..................... and add a 1/2 pint of Marvel Mystery Oil to your gas and oil about every 2000 miles. No kidding, the old high mileage cars really like it... I know
    Cheers,
    Smoke on decelleration could also be oil overfill. A common beginner's mistake...
    True, true.... Mr. Bond
    Apr 2003
    Portland, OR
    Smoke on decelleration = valve guides. I ran for 12,000 miles this way at 100-300 miles/quart.
    Check me at autox before my top end:
    Harry
    Member #789
    2009 MB C300
    Harry, You could have claimed it was tire smoke...
    Apr 2003
    Portland, OR
    Paul,
    I wore that excuse out after 2,000 miles.
    The rest of gang did appreciate that I was able to keep the bugs away from the track tho'
    Harry
    Member #789
    2009 MB C300
  1. Replies: 5
    Last Post: 03-19-2015, 10:54 AM
  2. Rsr question
    Last Post: 09-02-2012, 11:28 AM
  3. Replies: 2
    Last Post: 07-13-2011, 07:15 PM
  4. Value Question
    Last Post: 01-08-2009, 01:44 PM
  5. ST Question
    By Chuck Miller in forum Technical Info
    Last Post: 12-08-2005, 01:53 PM
