Results 1 to 10 of 12
Thread: locating white rivets and garage door safety
    I am trying to attend to some details on my 69E coupe and have been unable to locate the white plastic rivets that attach the outside threshold(sill) plate to the car. Can someone point me to a source?
    Also just a note regarding a somewhat related topic.
    If you don't have safety wires on your garage door springs(ones with two outside springs), consider getting a wire put in the spring to contain the spring should it break unexpectedly. It will save your car from being mangled by the flying spring, not to mention people or pets in the vicinity. I had one break, but luckily there was nothing in harm's way.
    Scott
    Scott:
    NLA, OOP, DISC., and the list goes on
    Seriously, I haven't seen any for years but that doesn't mean they don't exist. It's still one of the single best ways to tell if a car has been apart, though, because rivets usually show up where the plastic ones once occupied the holes.
    I'll do some "scrounging" this weekend and let you know what I find.
    If I were a bettin' man I'd say that Wurth would be the best place to start looking.
    Good luck,
    Tom
    Early S Registry #235
    rgruppe #111
    Apr 2003
    Portland, OR
    Re: locating white rivets and garage door safety
    Scott
    Have you tried McMaster Carr ? They have an incredible catalog.
    Do a search for Rivets.
    Harry
    Member #789
    2009 MB C300
    Anchor supplies these - its a perfect match.
    I didn't see any white ones............
    Tom
    http://www.itwautomotive.com/company/anft/
    rgruppe #111
    just got some
    from Dave Buhain, MS Road & Race:
    323-660-7674.
    perfect!
    Bahia Red '72 911S
    Meerblau PTS 2019 Speedster
    ES #333
    Scott, THanks very much for the safety tip! Any chance you could post a pic on how you ran the safety wire to prevent flying spring pieces, while still allowing the springs to do their thing?
    I'm going to a commercial operator on my main garage that uses a motor mounted to the side door. Not sure if the spring goes away but my main reason is to get ceiling height. I can pick up a total of 9'6" minimum. I plan on stacking cars on one side utilizing a Rotary Lift.
    If I had it my way I'd be buying commercial roll up doors (all self contained) but the better half would not be pleased.
    As is at least I get rid of the center mounted hanging operator and track.
    Tom
    rgruppe #111
    rivet part #
    Scott,
    The factory part # is 999.591.526.40 (plastic rivet Qty. 20)
    Ernie W
    member of Early 911S Registry
    It's in all springs sold today. Required by law. It's actually two solid wires that slide past each other always connected no matter if the spring is relaxed or stretched. When mine broke, I heard it all the way in the house from a detached garage. Sure glad I wasn't in there when it happened. That would have scared the crap out of me.
  1. Source of rivets for door pocket hinges?
    By Tom F. in forum Technical Info
    Last Post: 06-05-2008, 11:39 AM
  2. Lookin For White Plastic Drive Rivets
    By 69S-S/R in forum General Info
    Last Post: 08-31-2007, 10:29 AM
  3. WTB: Plastic Rivets for Door Sill
    By VinnyC in forum For Sale: 911 Parts
    Last Post: 04-04-2006, 07:03 PM
  4. 1972 911S Door sill Plate Rivets
    By lotus15racer in forum Technical Info
    Last Post: 03-10-2006, 06:54 AM
  5. Rivets for door sill?
    By 911pcars in forum Technical Info
    Last Post: 12-25-2004, 11:04 AM
