Results 1 to 10 of 14
Thread: RS Distributor
    RS Distributor
    Can any one come up with the GOOD Bosch number for a 73 RS Carrera distributor, the number in the book is...
    0 231 169 011 ... it has been superceded
    I have my 2.4-S diszy ... 0 231 169 005
    ... and I have a diszy from Roger G. ... 0 231 184 001
    The question is, WHAT distributor would you buy NEW for your 2.7 RS motor? ... (if you didn't want to recurve your own)
    ... and where the hell would you buy it... right now
    I don't know a fraction of what you guys know, but if that was my question, I'd call Andial. If they didn't have what you need on the shelf, they could always walk 100 feet across the parking lot and ask Mr. Springer. (Thier former partner, but you knew that )
    'Not so fast monkey-boy'
    Thanks Zeke,
    But the call to Andial had me goin in the same circles as everywhere else...
    All I'm lookin for is the exact superceded Bosch part number for the 2.7 Euro RS distributor... it could have made it all the way to 74'-76' Euro Carreras...
    Until I find the answer, I'll be tryin the distributor that Roger has given me (which number indicates it is from a 75'-77' CIS 911-S)
    If anyone has a recent RS project please tell me what distributor you used.
    Chuck, Warren Hall, Early S man, on a pelican post said my "RS" distributor is the one used on later than '73 EURO RS's, and is the proper one to use on a 2.7 RS of any year. I don't know where Jeff Gamroth got it, because I do let the shop supply parts when possible. I still have the box. The Porsche part number is
    911-602-031-FX. The Bosch number 0 231 184 004 seems to have been superceded to 0 986 237 017-090 .
    The latter number is printed in bold black on the box, the first number I gave is in smaller type with an arrow curving up to the bold black number. I'm not very good with part numbers, but hope this info helps. If you are still having no luck down there, you might give Jeff Gamroth a ring at Rothsport in Tualatin, Oregon. The number there is 503-885-9626.
    Thanks a bunch Paul... I'm on it...
    admin_old
    Guest
    Chuck,
    They're all pretty close in spec. If I were you, I'd forget buying an extra distributor. Use the one you have ('73 S). When you get the engine together, have a dyno shop perform a spark test (plot advance per horsepower/torque curve) for optimum spark advance (I should do this myself).
    Any factory advance curve will be a compromise, suited to work with variations in build tolerances and available fuel octane.
    Here's what I get from the factory manuals. I converted the charts from distributor degrees to crank degrees and engine RPM for ease of comparison and do not include initial (static) ignition timing:
    2000S engines (66-68 911S) Bosch dist. 0 231 159 002 (page L39, orig. factory manual, Vol. II):
    Eng. RPM Degrees (and factory variation)
    1000 0
    2000 14-20
    3000 14-20
    4000 14-20
    5000 14-20
    6000 18-24
    7000 19-25
    2.4S/2.7S except Carrera (page 9.3-2/3, Vol. VI, printed '73):
    Eng. RPM Degrees
    1000 0
    2000 20
    3000 21
    4000 24
    5000 28
    6000 32
    7000 32
    2.7 Carrera (page 9.3-2/7, Vol. VI, printed '73):
    Eng. RPM Degrees
    1000 0
    2000 4-8
    3000 13-17
    4000 16-20
    5000 20-24
    6000 24-26
    7000 24-26
    Observation:
    Can we assume a 2.7 Carrera is the RS engine (same as Euro RS)?
    If so, the early S and 2.7 Carrera distributor curves work with a little more initial static timing than the regular 2.4/2.7 engines. Variations between all three may or may not be optimal based on your particular engine but will work okay with factory spec engines.
    BTW, I'm using the 2000S distributor in my 2.7 set at 10º initial advance, but not optimized.
    Sherwood
    Thread located here: http://forums.pelicanparts.com/showt...tributor+bosch
    The following data is from the spec books and factory service manuals:
    All '72 models, and some early '73 models used:
    2.4 T --> Bosch 0.231.169.003 -- 6500 rpm rev limiter
    2.4 E --> Bosch 0.231.169.004 -- 7100 rpm rev limiyrt
    2.4 S --> Bosch 0.231.169.005 -- 7300 rpm rev limiter
    Using 'mirror image points' ... later '73 models used:
    2.4 T --> Bosch 0.231.169.008 -- 6500 rpm rev limiter
    2.4 E --> Bosch 0.231.169.009 -- 7100 rpm rev limiter
    2.4 S --> Bosch 0.231.169.010 -- 7300 rpm rev limiter
    1974 model CIS 2.7 engines used the '73 T distributor ... subsequently replaced by Bosch 0.231.184.002 -- 6500 rpm rev limiter
    1973 RS 2.7 engines used Bosch 0.231.169.011 -- 7300 rpm rev limiter dist. with quicker advance curve and more initial advance setting, later replaced with Bosch 0.231.184.004 -- 7300 rpm rev limiter ... used 'mirror-image points' with respect to the '73 models!!!
    __________________
    Warren Hall
    1970 911 T
    1977 911 S
    This is it. I was just about to send it out for restoration.
    1970 911 T
    1977 911 S
    Thanks Sherwood and Ray... I think we're sneaking up on it...
    Chuck, a 1974 European Carrera distributor is probably still available through Porsche NA from Germany. That is what is in my '72S.
    Randy Wells
    www.randywells.com/blog
    www.hotrodfilms.com
    Early S Registry #187
  1. 67S Distributor
    By ryanmadson in forum For Sale: 911 Parts
    Last Post: 12-12-2016, 11:01 AM
  2. FS: 71T Distributor
    By juche_namja in forum For Sale: 911 Parts
    Last Post: 02-19-2013, 11:05 AM
  3. WTB: '72 T distributor
    By Bob Alfonso in forum For Sale: 911 Parts
    Last Post: 11-27-2012, 06:09 PM
  4. Replies: 1
    Last Post: 08-03-2011, 10:40 AM
  5. FS: 2.4E Distributor
    By cscrogham in forum For Sale: 911 Parts
    Last Post: 12-30-2009, 10:21 AM
