Thread: clutch problems
    clutch problems
    Hi to all,
    Well friday on the way home, the clutch pedal went to the floor and no more shifting. On inspection when I arrived home it turns out the nylon T shaped apparatus at the trans end of the clutch cable was the culprit. The "ears" on the nylon piece just sheared off. Before I order a new OEM part, I'm asking you all if there is an upgraded part made of a more durable substance, and where I might find one. Oh yeah ..70 911S , 901 box.
    Thanks to all,
    David & 9110310111
    Jun 2003
    Toronto
    Same thing happened to me 15 yrs. ago with my 70S. I purchased from Stoddards a aftermarket piece made out of aluminum, havn't had a problem with this piece breaking ever. I'm sure they are available from many sources.
    clutch
    I thought i remembered seeing something about an aluminum piece before. I also remember being warned to replace this part as a precaution before it left me stranded. Thank god for good syncros!
  1. DFS Tooling Problems
    By juche_namja in forum Technical Info
    Last Post: 04-03-2013, 10:33 AM
  2. Help. 911 st electrical problems.
    By m12bug in forum Technical Info
    Last Post: 02-17-2013, 10:24 AM
  3. MFI problems
    By tom dance in forum Technical Info
    Last Post: 08-16-2007, 02:46 PM
  4. 73 MFI Problems
    By gunnar in forum Technical Info
    Last Post: 04-01-2003, 09:59 AM
  5. Problems with 73 radio
    By caproader in forum Technical Info
    Last Post: 09-17-2002, 10:15 PM
