Thread: still learning here: car rides too hi
    joelrkaplan
    Guest
    what is the more common/simple way to lower ride height on my 70 T...sits very hi...front more so... car has new oe style Boges and rides on Fuchs 14's...thanx...search came up empty....
    Goldmember ttweed's Avatar
    La Jolla, CA
    Front is simple- screw adjuster at rear of torsion bar. Rear is not easy without adjustable spring plates- torsion bars must be removed and re-indexed.
    Be aware that you are changing your alignment and corner weighting by adjusting ride heights, so these parameters should be checked and adjusted at the same time. If front is lowered too far, you will have to deal with bump steer issues as well.
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
    joelrkaplan
    Guest
    lowering
    thanx Tom..front sounds like it should not be too expensive to have a shop do from what you said...just want to get it down to equal rear more....will have align done too if necess....
  1. Sunday Morning Rides
    By setho in forum Drives, Tours, Gatherings, Racing and Adventures
    Last Post: 11-10-2013, 10:41 AM
  2. Learning to Drive
    By LongRanger in forum Off Topic
    Last Post: 09-16-2013, 03:05 PM
  3. Large print of your rides
    By cjtbt in forum For Sale: 911 Parts
    Last Post: 12-21-2010, 02:34 PM
  4. 912R - rides again
    By michel in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 06-14-2009, 06:35 AM
  5. R Gruppe,outlaws and factory rides - look here!
    By RPMClassic in forum General Info
    Last Post: 06-23-2005, 09:34 AM
