Results 1 to 10 of 20
Thread: High Compression 2.4 S Motors
    Mar 2003
    Santa Monica
    Hello there!
    Does anyone have experience fitting 2.2 S pistons in a 72-73 S to get a high compression motor?
    What would the compression be? Any valve clearance problems? Anyone ever dyno a motor to see what the horsepower gains are?
    I would think the (already mighty good) throttle response would be awesome!
    On the advice of my mechanic, who had built countless race engines, I decide to run 2.2S pistons with 2.4S motor. He says around 10.1 compression and 15 - 20 HP and no issues at all in building.
    Motor is finished but not yet installed or dyno'd so the proof will be in the driving I guess but I know it was done to lots of 2.4 race cars that raced successfully out here and I wantd a power upgrade that could be reversed easily if someone wanted to return the motor to stock 2.4S
    Clyde
    Australia
    Jun 2003
    Toronto
    Yes I have built one of these engines on a 7R case. I had clearance problems on the bottom of the stroke, the piston skirts just kissed the case at BDC so I had to remove a little material from the skirts. I have no valve to piston clearance problems as I am using "E" cams. Awesome engine!
    Rudy
    I just helped build a similar motor and will be building another similar motor soon. The just finnished T-E motor did have some piston-valve clearance issues but it wasn't bad and was more of a result of relieved 2.2T pistons combined with crane 288 cams (cross between S and solex). We did have to advance the cam timing a hair (still well within specs just not at the target timing) to get the required clearances.
    I will soon be building a 2.4E motor using 2.2E pistons and solex cams. I don't anticipate any problem with them. I'm hoping to make right around 180, 25 over a stock 2.4E. I would think that increasing your CR up the point, point and a half will definitly up your Horsepower throughout the entire rev range but I wouldn't expect a full 20 HP more though.
    According to Bruce 2.2S pistons in a 2.4S motor should bump the "book" compression value up 1 point or so over stock 2.2 compression, about 10.5 or so (don't remember the exact value here) but when measured out it will only be about 9.6:1 which is just perfect for a street car on pump gas.
    Just some thoughts from my research.
    Tim
    1973 T
    In Wayne Dempsey's book on 911 engines, this set up is one of his 'favorite' mods for a 2.4L. I did the same on mine as Clyde, but mines not wired up yet. I'm running it with Elgin's 'mod-S' cam. Wish I could give you the results, as I'm anxious to see how it comes out myself.
    Also, since I doing the whole rebuild at the time, we had Ollie's machine the lower covers for twin-plugs (just in case the compression is too high for the crappy gas we get here in NCal). I've not sprung for the twin electronics yet (still researching t-plug dist system a la RSR vs the more modern set ups out there - subject of a forthcoming thread before I decide).
    ....patiently waiting.....
    Chris Purpura @civilizedmisfit
    ___________
    Member #479
    Current Cars:
    1972 911T aka The "Civilized Misfit" Build
    See: https://www.excellence-mag.com/issue...vilized-misfit
    Miss February - EarlySRegistry 2023 Calendar
    1968 911S Ossi Blau/Beige Corduroy
    Past Cars:
    2019 911 Carrera GTS (sold, no regrets)
    73S - #1100 (restored and now somewhere in Europe)
    1997 993 Carrera 4S Black on Black (sold)
    My motor is a stroked 2.2S with high compression pistons. It's about 10.5:1 and I can run 91 with no problems - she makes good power all the way to 7200. Good daily driver with the MFI ... any questions, just ask.
    -Marco
    TLG Auto: Website
    I remember your car was in an accident but what's the current status of it?
    Tim
    1973 T
    Can you raise the CR for a 2.7RS engine in the same way. Any relatively easy mods to improve power for this engine ?
    Mike
    To ask is to seek denial
    Originally posted by l33t9eek
    9146,
    I spent a good portion of last night stripping the left front of the car ... we've acquired a donor/parts car and the patient is slated for surgery in the next week or so. The prognosis thus far is that the 914 will be making a return to the ring, maybe even by the Jan. 2? R Gruppe track day.
    However, nothing is set in stone.
    -Marco
    TLG Auto: Website
    Mar 2003
    Santa Monica
    Thanks for all the great answers and info.
    I talked to an well known parts supply house, and a fellow there said a good rule of thumb is an extra 10% power for every 0.5 point increase in compression ratio.
    Even if it's just a rule of thumb, that seems (wildly) optimistic to me. Any thoughts?
    Early 911S Registry #224
    911S Targa 1973
    356B Roadster 1962
  1. high compression 2.7RS engines?
    By swisscheese in forum Technical Info
    Last Post: 11-18-2018, 12:46 PM
  2. FS: High compression pistons...cheap
    By speedo in forum For Sale: 911 Parts
    Last Post: 01-15-2014, 01:30 AM
  3. 2.7 high compression p's and c's
    By tfiv in forum Technical Info
    Last Post: 10-04-2005, 08:20 AM
  4. Camshafts for a High Compression 2.4S
    By Edwin Ek in forum Technical Info
    Last Post: 01-10-2005, 05:37 PM
  5. High compression test readings
    By Baddger74 in forum Technical Info
    Last Post: 02-21-2002, 04:30 PM
