Results 1 to 2 of 2
Thread: brake calipers restoring
    Senior Member swisscheese's Avatar
    Jan 2003
    The Netherlands
    Hi,
    I'm in the process of building up my freshly repainted S. Next step is the brake calipers. It seems the alu. front calipers are fine, except for a small corroded section, on the edge with the "hole" where the piston sits. I guess the usual problem (between alu and steel), but what to do with it? Sanding the area and put blank paint on it?
    The rear ones I would like to restore in gold-passivated finish. Do I need to take them apart (and refresh the O-rings), or keep them intact and put them to "bath" as a whole unit?
    Thanks for the response!
    There is a place in Washington State, US that does a fantastic job. I don't know if you want someone else to do this or if you even want to ship to WA. Maybe they will help you anyway with some answers.
    http://www.goldlinebrakes.com/TechReport101.htm
  1. how much for a set of 67/68 brake calipers
    By moito in forum General Info
    Last Post: 01-15-2014, 05:18 PM
  2. 917 - RSR Brake Calipers
    By mrg3.6 in forum General Info
    Last Post: 05-04-2013, 12:19 PM
  3. S brake calipers
    By merbesfield in forum For Sale: 911 Parts
    Last Post: 02-02-2011, 05:55 PM
  4. WTB - S Brake Calipers
    By FL-Frank in forum For Sale: 911 Parts
    Last Post: 03-03-2008, 05:51 AM
  5. Restoring 'S' calipers
    By fryardds in forum Technical Info
    Last Post: 11-10-2004, 07:11 AM
