Thread: battery(s) charging
    joelrkaplan
    Guest
    battery(s) charging
    do you use a trickle charger?..brand?...how do I use for our twin battery set ups?...thnx
    Nov 2002
    Worshington State
    I use a generic trickle charger that is 1.5 amp that maintains the voltage at a constant 12.5. During the less driven months, there is a draw which eventually takes them down below cranking power (clock, CD player, and the ??? draw). Griots Garage sells a $60.00 model which you might consider
    Griots
    Nov 2002
    Worshington State
    The batteries are wired in tandem - when you charge one you charge the other.
    Schumacher's Mity Mite...
    Preformance Products - part # 840000... $38.95
    Got'm on the S and the Chevy... about 3 years, no problem
    Cheers,
    from the single battery guy...
    Century 1.5 amp on board trickle charger with auto shut off. A must have for winter challenged group.
    Pic available here. Pay no attention to the orange spots, they now reside at the bottom of my shop vac.
    Shawn.
    67 coupe roller
    99 M96 2.5 litre
    early911s reg 447
    R Gruppe 399
    joelrkaplan
    Guest
    thanx to all as usual...getting on it now!
  1. Charging new batteries
    By denson in forum General Info
    Last Post: 02-26-2014, 05:19 PM
  2. charging issue...alternator or voltage regulator
    By cmcfaul in forum Technical Info
    Last Post: 08-18-2013, 04:56 AM
  3. Battery / charging system question
    By obrut in forum Technical Info
    Last Post: 06-30-2011, 09:12 PM
  4. Charging Problems
    By 67SWT in forum Technical Info
    Last Post: 05-15-2011, 01:41 PM
  5. battery charging assistance
    By jdevil325 in forum Technical Info
    Last Post: 06-21-2008, 11:12 AM
