Results 1 to 8 of 8
Thread: Fiberglass engine shroud question
    Jan 2003
    NW Indiana
    Does anyone know if a FG engine shroud from a '72-73 fit on a '71 engine without modificaton? Thanks.
    Brian
    '71T
    R Gruppe #299
    Brian,
    A 71 shroud would be the same. The only MFI shroud differances is the color. A 71 "T" shroud would not work as those cars had carbs, thus there would be no cut-out for the fuel injectors.
    69-73 E and S would be the same. 72 T MFI and the first half of 73 T are pretty much the same. The later 73 T's were CIS injection.
    T shrouds were black, E's were yellow, and all S's were red.
    Jan 2003
    UK
    Rick - a slight correction to your post above:
    'E' fan shrouds are green.
    The early 'T' shrouds were black, then I think they went to yellow.
    Andy
    Early 911S Reg #753
    R Gruppe #105
    A- OK Andy.......Thanks for the correction! Carb T's were green, yellow were MFI.
    Forgot to add, that early E's were green also.
    Jan 2003
    UK
    Rick - I don't think 'T' shrouds were ever green.
    As far as I remember 2.0/2.2 T engines (& euro 2.4T's with carbs) had black shrouds & 2.4 T mfi shrouds were yellow.
    I think that 2.7 CIS engines then used green shrouds...
    Andy
    Early 911S Reg #753
    R Gruppe #105
    to early
    Right again, I should stay off the tech boards untill I have been awake for a hour!! New rule!
    One tip...the '73 shroud has a removable section that allows access to an engine mounted oil cooler nut that '72 & earlier shrouds don't. Alan Caldwell, August 2000 PANO, described '69-'73 shroud colors thusly:
    911T-black
    911E-green
    911S-red
    The exceptions: MFI 911T was yellow, and the '73 1/2 911T with CIS went back to black...
    Take notes guys, there will be a test later.
  1. FS: Amber fiberglass fan shroud
    By Bill Harris in forum For Sale: 911 Parts
    Last Post: 05-17-2013, 07:28 AM
  2. engine shroud on QRS Fiberglass
    Last Post: 05-14-2012, 05:31 PM
  3. WANTED: Bare Fiberglass Engine Shroud
    By Mr9146 in forum For Sale: 911 Parts
    Last Post: 04-15-2008, 07:14 AM
  4. FS: 67/68 911S Red fiberglass engine shroud
    Last Post: 10-14-2007, 04:52 PM
  5. WTB: Red Fiberglass Engine Shroud
    By J-P in forum For Sale: 911 Parts
    Last Post: 07-31-2006, 05:48 AM
