Thread: Starter question
    Starter question
    Were original starters the same '69 thru '73? Reason I'm asking is a friend has bought a used starter from a '70T, but he has a '71E that has a retrofitted 915 transmission. Will a starter from a 901 transmission car bolt right up to one with a 915? Or, will the newer transmission make a difference?
    Hi Paul, i believe 65-71's used the bosch sr-17x, and the 72-89's the sr-68x..... I think they are interchangeable with some fiddling, ie you need to wire up a relay for the cold start on later cars....
    Nov 2002
    San Dimas, CA
    The original 911 starter was the Bosch SR-17X, which is better known as the Volkswagen Autostickshift starter. It's widely available through VW suppliers.
    For trivia bugs: the SR-17X used in 1965 uses a pinion gear which is different from all the others. It's what a VW mechanic would call a 6 Volt pinion.
    Oh gosh...I was asking for Evren. Obviously, he was a step ahead of me, and did his homework. MIT must teach these things...
    admin_old
    Guest
    Hmmm. I've been using the same starter (SR-17X, I think) that I installed on my '69 when it was stock, then used it when I upgraded to a 2.7 w/a '78 915 gearbox. I've had no pinion-to-ring gear engagement issues.
    Hope this helps,
    Sherwood
  1. FS: Hi Torque Starter 911
    By jeffb in forum For Sale: 911 Parts
    Last Post: 06-18-2013, 02:35 PM
  2. 1971 starter question.
    By zenithblue71T in forum Technical Info
    Last Post: 05-26-2013, 11:48 PM
  3. New Starter?
    By cmcfaul in forum Technical Info
    Last Post: 01-29-2010, 10:36 AM
  4. WTB: Starter for a 73T
    By gruen911 in forum For Sale: 911 Parts
    Last Post: 01-14-2008, 09:36 AM
  5. The nut above the starter
    Last Post: 11-12-2005, 12:47 PM
