Results 1 to 10 of 16
Thread: oil pressure?
    oil pressure?
    After changing to Mobil1 in my 2.4S motor, my oil pressure has increased by 0.5 on the pressure gauge (0 - 10 scale). At 3200 revs the gauge reads 4 exactly.
    Is it normal when flooring it (from 4000 revs up) the oil pressure needle shoots up to the top (10)?
    I'm assuming if there was too much pressure I would know about due to leaks etc..?
    1973 2.4S
    1993 964 C2
    987 Boxster Spyder
    'hot66'
    www.ddk-online.com
    Question
    Excuse my ignorance if it shows but I've never seen a 1-10 scale. Ive seen scales to 140psi and also scales in Druck pressure on later cars like SC's and Carreras.
    A cold engine could easily pop 100 psi. Anyone remember the rule of thumb for pressure/1000 rpm's?
    Tom
    Early S Registry #235
    rgruppe #111
    this is a 'Druck' pressure gauge
    without concentrating too much on the actual values, I was wondering if it was 'normal' for the pressure to shoot right up when under flat out accleeration?
    1973 2.4S
    1993 964 C2
    987 Boxster Spyder
    'hot66'
    www.ddk-online.com
    oil pressure ?
    James
    What you are seeing is normal for a cold (ie less than 180F oil temp).
    The 911 dry sump system uses a two part pump; one side to scavenge the oil out of the sump and send it back to the tank and the other side (pressure side) to pressurize the oil galleries of the engine. Unlike most automotive engines the pressure side is actually a constant volume pump rather than a constant pressure pump. This allows for wild swings in oil pressure from just a few psi at idle on a hot or somewhat worn engine to 100+ psi when an engine is reved. As a rule 10psi/1000 rpm is acceptable minimum; anything less and you may have excessive wear in the rod bearings.
    As for your guage reading 1-10. I recall seeing this type of gauge before and beleive that it was in atmospheres. Meaning that 1(bar)=14.7psi. Hence 10(bar)= 147.5psi.
    I have to admit that unless the numbers you gave are for a cold engine it is unusual to peg the oil pressure guage when reving to 4000rpm. Most folks are a lot more worried about the opposite problem. Hope that helps.
    scott
    scott
    73S
    73E
    thanks for the reply. The pressure / revs relationship is correct under normal driving.
    The high pressure reading only slightly worried me, but I admit it was cold day & i had only driven about 7 miles so the engine was not fully warm. Not having been out in the car for 2 months I think I was just being paranoid, watching all my dials & listening to every noise
    1973 2.4S
    1993 964 C2
    987 Boxster Spyder
    'hot66'
    www.ddk-online.com
    Normal Oil Pressure Reading
    Both my engines are very recent rebuilds, and at normal operating temps (i.e. 180-210) they register 60psi @ 4000 rpms. At higher rpms they will move upward, but I was not aware that there is a specific ratio of oil pressure to engine rpms?
    EEEK! Try to keep the revs under 3500 until the temp is around 180, okay? Then if it still shoots to 100 at 4,000? It may be time to change the sending unit.
    Paul is correct:
    You can do a lot of damage to a cold engine. It is always a good idea to let it get up to operating temperature before a flogging.
    My M Roadster gets water temperature in about 2 miles of driving, however, it does not get oil temperature approaching the magic 180-200 degrees for a good 10-15 minutes. Only then will I pull the trigger.
    Digressing a bit, Harley Davidson’s have for years had a problem with base gaskets weeping. (they are much better these days from what I hear) The trick was to let the bike warm good before spanking the throttle but most clowns jump on them, crank them up and let the big dog eat. Lots of leaks and worse yet, a ton of premature wear. My bike machinist who is an old hand with BMW's and Harley's says you cannot believe what some ass-***es can do to a perfectly good engine. Of course it's more business for him but he does have sympathy for the machinery.
    Go to Daytona Bike Week one time and I promise you will see some of *the* most asinine behavior imaginable.
    Tom
    rgruppe #111
    remember too...
    that each of the diffent types of metals that make up our engines have very different expansion/contraction temperatures. So each have unique warm up times and optimal operating temps. You want all of them to be near their optimal expansion (limit) before you "...let the big dog eat."
    Nice quote sithot.
    HD rocker cover gasket destroyer, Shawn.
    67 coupe roller
    99 M96 2.5 litre
    early911s reg 447
    R Gruppe 399
    Apr 2003
    Portland, OR
    Tom
    Fully warmed up, it is usually 10-15 psi/1000 rpm.
    Harry
    Member #789
    2009 MB C300
  1. Very hi oil pressure!
    By Jay Laifman in forum Technical Info
    Last Post: 10-18-2013, 07:42 PM
  2. Oil Pressure
    By Jeff Trask in forum Technical Info
    Last Post: 08-29-2009, 05:54 AM
  3. Oil Pressure Light '68 911
    By 68911USA in forum Technical Info
    Last Post: 05-09-2009, 03:01 PM
  4. High Oil Pressure
    By RTincher in forum Technical Info
    Last Post: 03-23-2007, 01:04 PM
  5. Oil Pressure
    By KlaasyT in forum Technical Info
    Last Post: 05-04-2004, 07:28 PM
