Results 1 to 2 of 2
Thread: rear torsion bar woes
    Member, Human Race wit61's Avatar
    Jan 2003
    Pennsylvania, Northeast
    I'm attempting to adjust the rear ride height of my car (1st time). After removing the torsion bar cover and unbolting the spring plate, the assembly will not slide off the torsion bar, even with prybar pressure (see pic). I have read the archives, and can't find any missing step. Is this just a matter of using force or is there a technique ?
    TIA
    http://www.classicvelocity.com
    70 911T Targa
    70 911E
    73 914
    If you go flying back through time and you see somebody else flying forward into the future, it's probably best to avoid eye contact....
    Two pry bars. You don't want to 'wedge' it. Kind of a jerking motion seems to be better than gradual force.
  1. Replies: 0
    Last Post: 11-30-2012, 05:26 AM
  2. Rear torsion bar cover 73S/RS
    By ret9191 in forum General Info
    Last Post: 12-20-2007, 09:20 PM
  3. Rear Torsion Bars
    By A.T. in forum Technical Info
    Last Post: 05-10-2006, 08:16 PM
  4. Rear torsion bar bushings
    By bshea in forum Technical Info
    Last Post: 07-25-2004, 04:18 PM
  5. rear torsion bar bushing
    By scargo70 in forum Technical Info
    Last Post: 07-20-2004, 10:22 AM
